sbinh
- Jul 12, 2008
Actually it does. I was able to run
sudo ./smocng.sh 262
It ran fine.
Rebooted and it couldn't post.
It ran fine.
sbinh, that's impressive!Are you able to run at 261?
My system with 6166HEs topped at 260; 261 did not post. Still, this is a nice showing that HE CPU's are phenomenal!![]()
I use the flags: -bigadv -smp 36
But when fah runs, it maps only 32 cores![]()
This is due to the way domain decomposition works. When you get to using that many cores, not all values for the number of threads are valid.
Back when I had a 36 core system, I would run two instances of fah. The first would be -smp 32 running bigadv (and the kraken). The second was a custom version of the kraken that would bind to the remaining 4 cores running -smp 4.
What is the "SAFE" temp. for AMD chips? Trying to run 6176 with refclock= 247 and temp @ full load around 46C-50C... Should I keep running it at that speed or back down abit?
