sbinh
- Jul 12, 2008
1- What is the minimum requirement for PSU? Would Corsair TX850 be enough (with 1x 8pin y-splitter + 1x 6pin to 8pin adapter) ?
2- Can use only 1 cpu to setup, then add the rest later?
3- Can use Musky's method to mount socket 1366 waterblock for G34 socket?
4- Can use on board video? (just for display)
.....(may add later
.....(may add later
