Can we get some pics of your system and of the actual Kill-a-watt meter when the system is at idle.
You think I'm skewing results?
Dont get trolled by him. He got banned because of it.
I don't think I know you well enough to comment. I just asked for pics...if you can't or won't take them...so be it. If I had a kill-a-watt meter I'd take some pics for yah, no problem.
Did we ever get the grayed out AA issues fixed. Running a single 4870x2 and AA option is grayed out for me. This is my 2nd time installing the 8.54... noticed the 2nd time I am getting good idle tem
I just got my 4870x2 last night and installed these drivers, I too noticed issues with the AA being turned on but not actually working.
The card is quieter then most of you lead me to believe, with the case boxed up it just makes a low wrrrr sound no louder then 50db.
I am not all that into bench marking etc these are vs my 8800GT, I just play games namely Vanguard, UT3, UT2k4, and TF2. In vanguard my fps went from 30's in APW to 120's, for UT3 it went from 40's to pegging the 60fps limiter at all times, in UT2k4 I had 180's fps on all maps I ran, I have yet to try TF2.
Some that have installed the 8.54 driver seem to have the AA option greyed out. Not sure if it's an incorrect install or what. I have the AA options available with one 4870x2 with these drivers. I suggest you try following my guide to the T on my other thread. I won't even try installing another driver until the official 8.9s come out.
I have 2 X2s, the first time I installed the 8.54 following the "Cactus" guide, it worked but my AA way greyed out.
I cleaned out the driver/CCC install and did it again and it was perfect. AA and all.
I still don't think ATI is up to speed in CrossfireX for a Quad setup.
Although GPU-Z recognizes all the cores and says CrossfireX is enabled, I don't have the performance I'd think these cards are capable of.
What games are you judging this card by? My guess is you think this card was going to dominate Crysis. Not even Tri SLi can play crysis well at 2xaa @ 1920x1200 very high without stutters...etc.
I'm working on playing Crysis through on Very High 4xaa/16af right now on my single 4870x2, it's very playable.
The card Sapphire 4870X2
The Driver Version 8.52.6-080708a-058488C-ATI
The Monitor 1900X1220
The Main Board DFI LP UT X48 - TR2
The game COD4 Performance Perfect and FPS through the roof
Note: Drivers packed with card.
I must be the only one happy with my purchase of this card
I've never been able to get the drivers from the cd to install.
I'm finding the official 8.8s to give about the same performance. For me it was just the cod4 settings that made the difference apparently, not the drivers. I am seeing higher temps at idle though with the official 8.8s.
I get the same bad performance in Call of Duty 4 regardless of the drivers.
Dan what MB and what version of Win 32 or 64bit ?
I now wonder if chipset and bios play a role into the stability and performance of the 4870X2.
The DFI MB i use needed a new bios to be able to even run with the 4870X2 and this is a vary ATI ready board DFI and I think Abit were about the only MFG with issues running the 4870X2 and needed new bios.
So I have new up to the minute bios fixed or tweaked for ATI and all is fine
What case are you using? I'm using a rocketfish and ever since I added another intake fan I haven't seen my temps go up higher than 88 at load on auto settings.
I'm using an Intel D5400XS with the latest BIOS (1149) which was only released a couple of days ago. The OS is Windows Vista x64 SP1. Stability isn't generally an issue. The problem I've run into concerning lock-ups is most likely due to heat. When playing games I have to run the fans at higher speeds and the issues I was having didn't start until I added a second card for CrossfireX. However when I crank the fans up to about 80% or so I haven't had any lockups at all.
Do you notice any big gains in CrossfireX with two X2s......to tell you the truth I haven't yet, in COD4 or Crysis.
I did change out the goop with arctic ceramique, so perahps this is why my temps have been outstanding. I was pretty liberal when I added ceramique to both gpus...adding a nice thick line to each gpu before I pancaked it. I know pancaked isn't a word perhaps...but it feels appropiate.
You want it to be a thin coverage, using it liberally will make it work as an insulator.
I've haven't followed this thread for the past few days, but dan, did you ever get your 4870 x2 problems fixed?
That shouldn't have made an appreciable difference. Typically the difference between thermal pastes and TIM pads is about 1-3c.
They don't use TIM pads on the gpus. That's only on the memory and volt regs, and pcie chip.
