vanilla_guerilla
- Oct 3, 2005
i dont have that game, but the numbers for that and the crysis results seem way off. and dont agree with the few other reviews i have seen. or my own results.
Yay for you! The Zalmans will make a huge difference if you use them. I just finished up my card this morning.
I see. Might reinstall warhead just to see how it runs. Going to keep the aluminum
heatsinks on the ram...and keep things simple. I figured if sapphire thought it was efficient
enough...might as well. Anyways when I got the water blocks on this thing, heat
transfer is so efficient that the board remains cool to the touch...I would think that in itself
would help keep the ram cool.
I'm really interested in seeing sandman's results on the 4850 CF vs 4850x2. Are there any reviews out there?
Right now I'm on a 19" 1440x900 but I'm on the verge of getting a 24" 1920x1200 or the 23" 2048x1152. I've got one 4850 and am contemplating getting a second. So far all signs point to "it varies from game to game, but overall generally better performance." Which I'm fine with. I'm really not considering replacing my card with anything else, but just curious about any performance difference between CF and x2.
I don't know what the hell people are talking about when they bitch about the fan noise... Sure it gets a little noisy if I crank the fan speed up to 100% but what the hell environment are they expecting to operate in. My case blocks out most of the noise and even if I take the side panel off it isn't that bad. The ATI auto fan control works well and the fans hang around 20 - 30% most of the time.
Haven't tried to OC the card yet... but i did achieve a long time goal of scoring over 20,000 in 3dMark2001 (don't laugh my last build was a P4 northwood with a 9800pro)
Do you guys keep the computer up on your desk or is it on the floor next to it ? I mean, if I turn all of my case fans off I can hear it but even then it isn't that bad....
Just trying to get a feel for what the complaints are about. Of course all of this is relative
i keep mine on the floor now with all case fans on hi. while i dont use delta 120x38 or 120x76 fans anymore noise level has never been a primary concern with me. i use lots of voltage so i need lots of airflow. i swap out my hardware way too much to watercool, ie i would be hunting down new waterblocks constantly. i got the zalman silent heat pipe psu, but i didnt even consider how loud or quiet it is when i bought it.
Wow I thought it would be more than that. I got over 12,000 just with the 4870 512MB.
TheSandman2236, you totally need to throw one of those single 4850s on there and try out some Tri-fire love. I'd love to see how well it scales.
Doesn't crossfire only scale the cards to the lowest card available?
thats the way i understood it. so a 4850 with a 4850x2 would be like 4850 512mb crossfire. i think.
The Vantage Performance score is going to be weak...no PhysX. I get around 10,500 with just a dual Core 2 @ 4 Ghz. Most of the tests get double the FPS of my old GTX 260 (which scored around 12,000 in the same system), but the physx tests just kills the score with the X2.
It honestly bruises your ego a bit to have a lower score with a dual GPU card, but my gaming performance is significantly better.
