wow i thought i read what you wrote wrong vega. 3gb video cards.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814261098&cm_re=gtx_580-_-14-261-098-_-Product
I am on the notify list so I can pick up a 4th card. To think all those cards sold so fast and left me hanging with only three. Then again I don't have a MB that will support four yet unless I could get SLI hack to get it to work on my P67 board.
Gainward's 3GB GTX580 is available in the UK, at least:
http://www.scan.co.uk/products/3gb-...5-gpu-783mhz-shader-1566mhz-512-cores-dp-hdmi
Horrendous amount of money to pay for a graphics card though. I think it's fair to say these are only really useful when you have three of them, or two at the very least, and that makes them an extremely expensive option.
Vega: How long is 'super short'?
I would say the included 6 foot cords that came with my monitors pretty short. They are pretty beefy and include ferrite beads and I did not have signal problems with them. When I increased to after market 10-25 foot chords I had all sorts of signal problems.
Thanks for the Hard work Vega, truly appreciated by all of us
Two questions for you.
How much of the performance increase do you believe was from adding the third card in comparison to adding the extra memory?
Do you think the 3gb Vram will have an effect at 3600x1920? You inspired me so much my 3 ZR24w's are on the way
As you can see by a lot of the numbers, on the regular 580 the memory limit was really holding them down. Once you remove that limit and add a third card it really let everything work well. You can clearly see this in the Heaven 2.1 and A-10C numbers in which the 3GB cards scaled way past where they should have versus two regular 580's. Not just in FPS numbers but also smoothness.
You might be right on the border if 1.5GB will be enough or not. Depends on what games you play though and if you like AA or not. Some games use a ton more VRAM than others. If I was planning a Surround setup from scratch, I'd definitely spend the extra $100 per card for the 3GB.
