Lateralus
More [H]uman than Human
- Aug 7, 2004
That'll be a great match.
So i have the LG34UM95 and have been using newer nvidia cards with hdmi 2.0 to get 60 fps with custom profile but with possible amd fury X not having hdmi 2.0, can anyone who has the same monitor and AMD 290X comment on sleep issues or other issues using displayport? Was this an nvidia and LG issue or just displayport issue with LG?
I run displayport with my 295x2 and have yet to have a problem.
I thought others had this issue too
it's the monitor that goes into sleep mode, not the computer
if your computer turns off (as in shuts down completely), the monitor then realizes there's no input. It will sit there and try to find an input for a few seconds, then go to "sleep"
that's when it's practically off, and isn't recognized by the PC until you press the god damn power button on the monitor again
whoever thought this was a good implementation at LG......ugh.....recently came back to a UM95 and forgot how annoying this issue is
I never use sleep mode, so that's probably why. As fast as my system boots, there is no reason for me to use sleep mode.
But i was using hdmi 2.0 custom 60 fps with no sleep issues so i guess thats the only fix for now. It limits my option a bit and is an additional factor in deciding fury vs 980 ti if it is true fury lacks hdmi 2.0. Just curious if it was nvidia specific or general display port. Im not going to replace this one year old monitor unril something significantly better comes along
So does that mean u can turn off computer and monitor can be left on without it turning on and off?
Well, going to have to discourage anyone from purchasing the DELL so far.
Got one from Amazon, and it was a dud and kept powering on and off constantly out of the box. There was also a big dent/scratch on the side of the plastic like some muppet had dragged it across the floor on the factory line. Decided to call up DELL directly and after some frustrations with their support line (don't bother), I went to the twitter DellCares team - much better! Anyway, they got a brand new replacement sent out to me.
Not so great. Power issue wasn't there, but instead there was horrendous backlight bleed and marks under the screen near the bottom. Not dead pixels or anything, but small blotches on the panel itself that spread out across a few pixels. Well, that wasn't going to work out either, so back to the twitter team. Cue another replacement (new, again).
Backlight bleed again, but I made it minimal by massaging the panel (that actually works quite well!). However, three of those splotch like things again. Makes me question where the hell they're assembling these, if these are pieces of dust or something. Was quite hard to tell if it was dust or not, to be honest.
After I told the twitter team about that one, they called me just now to say they're done helping me, which is fair enough since it came from Amazon I suppose. I'll just have to refund and sit this one out for a while.
All in all, I can't recommend the DELL as of right now due to the QC issues. Every panel was an A01, the first one being January 2015 and the others March 2015. As of right now, if you're looking for an IPS ultrawide I'm going to say don't bother and just keep waiting. LGs support is a dud and DELL QC seems to be taking a back seat despite how much these cost.
I kept the pictures of the faults I detailed when I sent them to DELL, if anyone is that interested in seeing it.
I totally agree.
And on these, three just seems waaayyy too wide to be realistically usable.
I know people are tired of me saying it but Climber, consider a 40" 4K. Your dual 980Ti setup begs for 4K, and a 40" is both wider and taller, so your field of vision will be immersed in gaming goodness. You won't gain any extra FOV in games, but it's well worth the tradeoff.
Guys this might be in the thread but its 200 pages so I hope you dont mind me just bumping and asking.
I have the 34um95 and sometimes when it wakes up from sleep the right half of the screen is completely distorted and has to be turned off and on and this fixes the issue.
Anyone know of a fix to this?
I owned the flat LG 34" (own the curved 34c97 now) and sometimes had the same problem (2 x 980s in SLI). Seemed random.
After I went to the curved model, initially I had some of the same restore from sleep issues (using 2 x 980s in SLI) that many posters have had here. Eventually, i gave up on a solution and went back to the dark days of actually setting a Windows screen saver! This solved the problem. Later, I replaced the 980 SLI setup with 2 x Titan X's in SLI, and decided to turn off the screen saver and give sleep mode another try. It worked fine. I dont know if its video card specific or what. But the 2 x Titan Xs restore from sleep mode just fine using a DP connection, standard 3440 x 1440 resolution @ 60 hz (i.e., not doing any of this custom resolution stuff people have been talking about). So who knows.
Anyway, not to be a dick, but I'd say the monitors originally talked about in this thread title are going to be "dead" as soon as the Acer Predator drops. (for gamers anyway). If that thing turns out to have a decent pic, color wise, and not too much IPS glow / black light bleed, its going to be the cats meow of high end gaming screens (for me anyway). 34" 3440 x 1440 @ 100 hz (assuming you have g-sync capable cards). I would expect sales of "normal" 60 hz 3440 x 1440s to plummet though you could get a really good deal on a used one, like MINE
Mine is being sold the day that Acer comes out (September hopefully)
While not the same model, I got the 34UM67, god i love this thing, I didn't want the higher res, because then I'd need more gfx power
Well, at some point monitors like the LG 34UM95 will be obsoleted by newer and better monitors. At least I hope so. Hate to see stagnation in the industry. 40K monitors will do them in eventually once the industry gets their act together and make some better monitors but I believe the 21:9 will be around for some time to come because not everyone will want 40k and 21:9 is the closest alternative to 40K. Anyway here's to hoping progress moves faster.
In the future, there are only resolution wars.Dude. Too much Warhammer.
Others have done so, but reported seeing dropped frames (which software utilities don't detect).I've successfully overclocked my Dell U3415W to 80 Hz. 85 Hz gives an error on the monitor. This is with a GTX 970 driving the monitor.
http://imgur.com/aOjwvNy
How do I test for dropped frames?
UFO Test: Frame Skipping Checker: www.testufo.com/#test=frameskipping Scroll the page down slightly to see the verdict below the grid.
Correct. The "Valid" has nothing to do with whether or not there is frame skipping. The "Valid" just indicates that the page is ready for you to assess skipping (either with a camera or with your eyes).That doesn't work; you need to take pictures w/ a camera (even a Nexus 5 works if you use one of the manual camera apps). It said it was valid but I could clearly see it skipping a line.
40K? Did we skip 5 - 39K and go straight to 40K?Well, at some point monitors like the LG 34UM95 will be obsoleted by newer and better monitors. At least I hope so. Hate to see stagnation in the industry. 40K monitors will do them in eventually once the industry gets their act together and make some better monitors but I believe the 21:9 will be around for some time to come because not everyone will want 40k and 21:9 is the closest alternative to 40K. Anyway here's to hoping progress moves faster.
