34" 21:9 UltraWide Displays (3440x1440) - LG UM95/UM65 & Dell U3415W
Discussion in 'Displays' started by anonuser, Jan 10, 2014.
  1. Azzkiker
    Azzkiker Limp Gawd
    353
    Apr 4, 2012
    Moore's law is so 2014... :D
  2. Skott
    Skott 2[H]4U
    3,983
    Aug 12, 2006
    LOL I don't know where that zero come from. I must have been typing asleep to not see that typo. My bad.:D
  3. jackstar7
    jackstar7 Gawd
    568
    Jan 7, 2012
    My 34UM95 now works with DP 1.2 enabled with no issues.
    Things that have changed since I last tried it: Win10 installed (from Win7) and now running on a 980ti (over a 7990).
    Anyone else check?
  4. BababooeyHTJ
    BababooeyHTJ [H]ardness Supreme
    6,950
    Jan 21, 2009
    Or 2005 :(
  5. RS1
    RS1 n00b
    10
    May 6, 2015
    I've got the AOC 3440x1440 (same panel as the LG UM95 apparently). I also have a 980Ti (gigabyte G1) but am still running windows 7.
    Experiencing issues with DP 1.2. Did you update your cable/drivers?
  6. Gomez
    Gomez n00b
    26
    Aug 8, 2014
    I just checked, expecting to switch it over to DP 1.2 and see if it worked, but to my surprise, 1.2 was already enabled. Apparently, I've been running DP 1.2 for months. I must have enabled it and forgot about it. I run Win8.1.
  7. jackstar7
    jackstar7 Gawd
    568
    Jan 7, 2012
    I did not update my cable, but my drivers are the latest version. So it might be a Win7 shortcoming of some kind... hmm.
  8. Gomez
    Gomez n00b
    26
    Aug 8, 2014
    Can't be. Win7 is perfect! j/k LOL
  9. Hatlesschimp
    Hatlesschimp n00b
    32
    Jun 3, 2013
  10. Originalas
    Originalas n00b
    9
    Apr 21, 2012
    Any news or hands on impressions about S34E790C?
    I have found only a few reviews and all says it's superb monitor, though what about this video? Maybe S34E790C owners could give an opinion?
    https://www.youtube.com/watch?v=esI3Vt8C_Uw
  11. Ail
    Ail n00b
    51
    Aug 20, 2015
    Hey all. I'm putting together a z170 itx rig and decided I should go all out and pick up a new display as well. I'm planning on running an itx sized gtx970 so 3440x1440 will probably be too much to handle with high settings for games. Primary use is not for gaming but I do like to pick up pc exclusives from time to time.
    29" is definately a bit too skinny for me so I'm looking at the 34s. Do I just pick up a 34um67 with the 1080 resolution to save some cash? (find them in the low 400s). I'm leaning towards the um95 just for extra desktop space, better ppi and a bit more future proofing. If I do go 1440 can you run games at 2560x1080 and scale them up without it looking horrible? I'm already going over budget on the PC and even if I wanted a 980 or sli I'm not going to have the space/power to do so.
    Thanks for any opinions.
  12. Lateralus
    Lateralus More [H]uman than Human
    14,729
    Aug 7, 2004
    I would get the 3440x1440 model, especially if the primary use isn't for gaming as that extra space on the desktop will be very nice to have.
    Unfortunately I can't comment on scaling as I never ran mine below the native resolution, but at one point I had a GTX 970 and most games ran fine at 3440x1440. If you do have to scale back to 2560x1080, I wouldn't think that it would look awful. I'd much rather have the higher resolution for day to day use.
  13. doug_7506
    doug_7506 2[H]4U
    3,223
    Oct 17, 2004
    I use a 970. You can still toggle some high setting for most games and get decent frame rates. Also, in my experince, you can run 2560*1080 on a 3440*1440 monitor without any problems.
    A monitor is not like a gfx card for most people. I change monitors every 5-7 years. I change gpus ever 1-2 years. Get the monitor you want now and upgrade your gpu when you want to.
  14. Ail
    Ail n00b
    51
    Aug 20, 2015
    Thanks guys! just needed a push off the edge :p. I see refurbs and used ones in the 600-650 range. I assume that's the best price I am going to find? There are a couple of deals on new ones but even with extra 10-15% off they are still high 7s - mid 8s.
  15. Skott
    Skott 2[H]4U
    3,983
    Aug 12, 2006
    A new um95 can be had for about $850-$900 so the prices you are quoting are the best you can probably get used or refurbished. Be careful when buying used or refurbished.
  16. Ail
    Ail n00b
    51
    Aug 20, 2015
    Yea, not sure I'll go referb but used doesn't scare me as much depending on the seller. Newegg has a 15% off deal right now from 899 so 765ish new, that is pretty good. Thanks again! Now if the z170 itx boards would ever come out I'd be in business
  17. Lateralus
    14,729
    Aug 7, 2004
    There's no way I'd pay $800-$900 for a UM95 at this point. I paid that price a year ago, and there are better/cheaper options now.
    Ail, if I were you I would wait for a deal like this. Curved and cheaper...
  18. Skott
    Skott 2[H]4U
    3,983
    Aug 12, 2006
    I agree the um95 was and is over priced. Many of the monitors that are out are over priced IMO but what are you going to do? The manufacturers have us over a barrel. We can vote with our wallets but the industry seems to not care. Just have to keep looking for deals and share info. :D
  19. jackstar7
    jackstar7 Gawd
    568
    Jan 7, 2012
    And there's a risk with voting with your wallet that by not buying these, companies will interpret that as unpopular and stop production... and then we get nothing.
    It's a seller's market for these niche cases.
  20. Ail
    Ail n00b
    51
    Aug 20, 2015
    Damn that was a good deal. Is the dell better than the LG though? I thought they used the same panel but I may have gotten mixed up During my research. I'm still on the hunt (I missed the one I was looking at for 620 on the bay yesterday) so if there are some better models for around the same cost (new vs new) I'd be interested to take a look.
  21. Lateralus
    14,729
    Aug 7, 2004
    Well I had both and as far as image quality I thought they were about the same, but I preferred the Dell just because I thought the curve added a bit of immersion. Plus Dell's warranty service is about 100x better than LG's if you need a replacement monitor. Just saying, if you can find the Dell for the same price (or less) it's a no-brainer IMO.
    I would also consider the Samsung S34E790C, but I haven't seen it go below $900 yet and it's been out for months. The Dell has been getting the best sale prices.
    I just think these 34" ultrawide monitors are overpriced for the most part...they shouldn't be $900-$1000 when you can get 40" 4K displays for the same price. The ultrawides should be at most $700, IMO (except for the Acer Predator since it's high Hz and G-Sync).
  22. Ail
    Ail n00b
    51
    Aug 20, 2015
    Gotcha, that is what I assumed but wanted to be sure I didn't miss a model. I like the idea of dual monitor style options without the bezels right in the middle so I dont mind a slight premium for that luxury but 1k is too much. I'm with you on the 700 range though. If they were 699-750 retail, deals and specials would push them down to low 6/5 which I think is good for the size as long as the panel quality is there. Premium for the curve is expected as well but again should not be so much. Now that I know the curved dell was going for 700 I will expand my search a bit. if I can get a curved 34" 3440x1440 to my door for less than 7 I'll be happy. Thanks again
  23. Anemone
    Anemone Gawd
    892
    Apr 5, 2004
    DP 1.3 is needed first before this is possible but a larger 21:9 will sell like hotcakes. Sales keep improving as they've made them bigger. Every major monitor vendor (HP, Acer, Dell, LG, and so forth) all have 34" models in their lineup. Not since 27's has a size been so quickly drawn up by so many vendors all at once. That's a good sign.
    37-39 or so 21:9 where height is 2160 and width is 5040 would be about perfect. Large yes. But if the sales of the current gen are any indication, this will simply widen the user base even further.
    DP 1.3 would also allow both 34" and 39" models with AdobeRGB and 10bit full color, which 1.2 can't do very well.
    Just food for thought :)
  24. toncij
    toncij [H]Lite
    69
    Sep 30, 2012
    I hope next gen cards will be 1.3 or we're not going to see those monitors until 2017/2018. Hopefully we'll then see 50" 5040x2160 and 6880x2880 34". :)
  25. Skott
    Skott 2[H]4U
    3,983
    Aug 12, 2006
    I agree. Its a catch 22 at times. :)
  26. Skott
    Skott 2[H]4U
    3,983
    Aug 12, 2006
    I would definitely trade up to a 39" or larger 21:9 if it was of good quality. :)
  27. mrkazador
    mrkazador Limp Gawd
    134
    Jan 21, 2011
    Is there a difference between the 34UM67 and 34UM67-P
  28. Originalas
    Originalas n00b
    9
    Apr 21, 2012
    So does anyone own S34E790C here? Has any comments about this video and showed problems https://www.youtube.com/watch?v=esI3Vt8C_Uw
  29. Sorcerer_Tim
    Sorcerer_Tim [H]Lite
    117
    Oct 8, 2009
    I have had this monitor since its release and really enjoy it. I came from a ZR30w which I liked, but wanted to try a curved, wider screen, higher resolution display and will never go back. I had the non-curved LG 34" 3440X1440 monitor, but sent it back due to backlight bleed and a few dead pixels. I am sure the price has dropped considerably since I bought mine, but when paired with enough GPU horsepower, it really shines. I will be the first to admit that I am not super sensitive to font distortion, uniformity issue and such, so YMMV, but overall I really like the display.
  30. Lateralus
    14,729
    Aug 7, 2004
    Hey, Ail!
    Massdrop just dropped a 34" LG 3440x1440. It's basically the 34UM95 but without Thunderbolt connectivity. If 15 people join the drop, the price will be $699. There are already 3 people committed and there are 11 days left, so I'm sure it'll happen.
    This might be your chance if you're not set on one of the curved models.
  31. hordak
    hordak Limp Gawd
    185
    Sep 9, 2005
    Damn this looks good. the AOC U3477PQU is $700 at Best Buy though. Dammit, decisions!
  32. Ail
    Ail n00b
    51
    Aug 20, 2015
    Thanks for looking out! Not totally sold on the curved but if I can get one for just a little more I'll take it.
    How does the AOC stack up? I have not seen much discussion on it.
  33. Lateralus
    14,729
    Aug 7, 2004
    Here's the thread on the AOC. I really don't know much about it, but read away!
    You might check overclock.net also. They usually have huge threads on monitors.
  34. mrkazador
    mrkazador Limp Gawd
    134
    Jan 21, 2011
    Adorama has the 34UM95C-P for $675
  35. Ail
    Ail n00b
    51
    Aug 20, 2015
  36. hordak
    hordak Limp Gawd
    185
    Sep 9, 2005
  37. jackstar7
    jackstar7 Gawd
    568
    Jan 7, 2012
  38. Skott
    Skott 2[H]4U
    3,983
    Aug 12, 2006
    That's a good price. I paid $999 for mine when it first came out. About time they started dropping the price on these units. I wonder if they are about to release a new model to replace it? Holiday season isn't far off. :D
  39. Zelda
    Zelda n00b
    9
    Aug 27, 2015
    I own the Dell and LG curved 34 inch displays. I find myself only using the Dell because the LG has a very annoying bug where the screen turns to snow if the computer goes to sleep or gets rebooted. To get the LG to work again I have to physically flip the switch off and on behind he monitor. This gets old very fast. The blacks do look slightly better on the LG, but it's hardly noticeable. Definitely not worth the $400 premium over the Dell.
    (34 inch displays)
    Dell 34 inch curved (U3415W) -- best priced 34" curved display, good picture, vesa mountable, good colors, no backlight bleed speakers suck, bottom of bezel a little warped
    LG 34 inch curved (34UC97) -- way too expensive, buggy, thunderbolt doesn't work, ports hard to get to on the back
    (27 inch displays)
    Asus MX27AQ 27-inch -- thin, light, good speakers, amazing color no Vesa
    Dell UltraSharp U2715H 27-inch -- thin, light, good color, Vesa no speakers
