Srsly, you need to do some brushing up on your knowledge.
I have a Dell 3007WFP-HC 30" LCD running at 2560x1600 and it's hooked into my SINGLE 8800GTS... not only that, it's using ONE of the TWO dual link DVI ports available on the card. I have played Oblivion at 2560x1600 at near full details and the card isn't even breaking a sweat.
In other words, you DO NOT need SLI to run a 30" LCD in 2560x1600 resolution...period.
I didn't mean to imply taht you need SLI to run a 30" LCD.. I misread what vegabond said, I thought he wanted to run a 3007 PLUS a 2407.. instead of 2407 vs 3007. Also I did not know that you could split a DVI port via a cable, now I know
As per the person saying I talked shit, I wasn't talkign shit simply trying to help.. I misread the post
I never said you had to have SLI to run a 30" LCD.. I meant to say you needed TWO cards to run a 30" display PLUS another monitor.. As i did not know you could run the 30" with a splitter off of oen DVI port. A simple mistake. Appologies
