- Mar 18, 2010
msi x-570-a pro
Yes, your 2nd x16 slot goes through the PCH. That means it will be sharing bandwidth with your 2nd NVMe drive, SATA, USB, ethernet, etc, but shouldn't slowed down too much.
msi x-570-a pro
Offer was just accepted for 200, good luck to everyone else buyin'. Mine will be here by the 27th, so I'll update with endurance numbers once I get it fired up.
The Samsung 830 drives we got like 9 years ago are still all going. So not all consumer drives are made equal.Nice to see some enterprise gear being spotlighted here. These things have some incredible durability too and will be still working when the best of consumer drives have already failed long ago.![]()
Dang... thinking about getting one of these for my ESXi server, will it support it? As if my memory bottleneck could get any worse.
Are your gaming raid 0 numbers suffering for the failing drive? Im surprised that RAID array isn't faster than that? The 3.2GB drive is stealing your RAID array’s lunch money!Yeah, I got it because one of the 5 drives in my array are shitting out. Went from 72% health to 1% in one day. Still works, but I get the random hiccup.
Also — What temps are you seeing. There is some question if these require active cooling.
Should be fine there for sureMine hangs out at 47 idle 53 loaded copying the raid over to it. Pretty reasonable. It's directly above my video card too. I do have a lot of fans in my case though.
Are they, though?They are slower than nvme drives... So really not much benefit
Are they, though?
Sequential, sure, but sequential isn't the interesting number. 4K QD1 benchmarks look about the same as modern NVMe drives.
No, they aren't horrible for sure. I have an old server that I may pick some of these up for since my server is pcie 2.0. They seem like a decent deal.Are they, though?
Took my offer at $200 yesterday. This should work great in my R710 SQL server (the stock PERC 6i is the bottleneck right now).
Thanks! got one for 199.96. 3.2TB will replace a 500GB NVME gaming drive (thats 90% full) that I have installed via a PCIe card in one of my 16x slots. I seriously doubt I'll see a big difference in load times between the two, and at $200 for 3.2TB...yeah, no brainer.
the old ssd mlc chips were really bad
Used to have few LSI, Micron and OCZ (similar enterprise grade ~1tb ssd's on pci-e) in old company i was working at the time used for saas search engine indexing, was chewing through them within a year. (and those were SLC not weaker MLC - and they were really expensive)Not enterprise drives that were 10+ thousand US dollars when they were new.
