D
Deleted member 88227
Guest
Similar to F@H, but different projects. I'll walk you through them when you're up and running.
9700k bought as temporary test processor. Will sell to any hard forum member when 9900k arrives for reasonable shortage price or MSRP. (paid 530 for it at current) bought it from a store though. Fuck it, I need to know if my gear will POST and I'm not waiting another minute.
I was trying to fit the second sata ribbon plug into hard drive number 2. FOr some reason I was unaware I was applying pressure to drive number 1. even without a clipped plug I tore the plastic guide right off. I didn't know that was possible. when windows gets installed I'll find out if it was my drive I preloaded my steam games on.you get mad and rip the sata power cable from that brand new 4TB Black?
I wonder if they'll replace it, betting that's a no.
I don't know what the hell I'm going to use it for now. It might last in the dock until the dock or drive dies of natural causes. Maybe a redundant backup? any way to make use of it outside of myself if there's no reason for it? I mean it IS broken technically, so I'm not going to rely on it.just have a fan blowing over it if you are doing constant transfers from it, since it will get quite hot.
I grabbed this room fan and just pointed it the drive in the dock,
the plastic piece came out in pieces and I dont have a soldering iron. this will be quite the learning experience. Where do I get a replacement plastic piece, and an iron?if it were mine, I would probably solder on a pigtail and mount it in a pc.
not sure about the plastic part since that is one large molded part.the plastic piece came out in pieces and I dont have a soldering iron. this will be quite the learning experience. Where do I get a replacement plastic piece, and an iron?
