integrate.this
- Dec 27, 2008
Just a little update - I got the display's USB connector working today - that includes speakers, USB hub, and iSight. I also have the brightness controls and special keyboard functions working.
Installing Boot Camp 3.0 on a non-Mac (64-bit)
Note: If after the hard freeze, boot camp isn't loaded, seek it out in Program Files (x64). Open it from there, and it should work.
Again, I am not sure of the negative repercussions of installing Boot Camp on a non-Mac. But so far, nothing too bad has happened, and I have access to the full feature set of my display. Awesome!
- The speakers and USB hub work out of the box. Windows recognizes the devices and installs the drivers. Done.
- The other stuff requires a bit of tricksyness. I installed Boot Camp 3.0 (gasp) on my non-Mac. This filled me with a sense of dread, and I've yet to see if there are any serious negative consequences. I hate installing all of those useless drivers. But here's how you do it, if you're crazy like me.
- Grab your Snow Leopard DVD. The Bootcamp folder has a setup program. This won't work - it knows that something's... different... about your computer. Dig in one folder deeper for BootCamp64.msi. This guy requires admin rights to run. To do so, open up a command prompt with elevated privileges and run it from there.
- The installer will begin installing a truckload of useless drivers. But don't worry. Everything will be okay. (Maybe.)
- Restart. Upon restart, my computer had a mighty spasm, and hard froze for a few seconds. This was likely Boot Camp realizing that it had been tricked. After my computer came back to life, though, it was working fine. Just open the boot camp control panel to adjust the brightness. The keyboard and iSight should work now too.
