Will not work with thunderbolt equipped iMac. Try pressing command+f2 on the iMac to force it to switch to display mode. Also try winkey+p on the PC to switch to extend or mirror mode.
Thank you very much ive been reading all over the inet and yes seems among all the cards in the world , my sapphire 5850 aint supported (event its a great card!!), however i managed now after i press cmd+f2 to get some black screen on imac and dell monitor for few seconds then returns to native OS on both screens (even in catalyst it say unknown monitor for a while!!), but i guess it still doesn't work....a. Nope, it should be automatic...when you have a compatible card.
b. As you might have seen by reading this page earlier in the thread, the 5700 and 5800 series are not compatible unless they are Eyefinity models... There is something wrong with the implementation of DisplayPort in the older series cards that the iMac rejects the signal.
c. If not for your video card, I believe that adapter should work.
d. No setup. The only thing you can do is cmd+F2, which of course didn't work.
Time for a video card upgrade?
I can say that my 7970 works, and I have a very similar iMac to yours (mine has 32GB of RAM, and I have not downgraded to Mountain Lion).
I haven't seen any posts with someone using a 7870 and confirming it to work on the 2010 iMac, but since it's so similar to the 7970, it's very likely that it will work. All you need is a miniDP to miniDP cable.
Sorry, that was a little jab at Apple. I consider Lion 10.7 to be a downgrade from Snow Leopard 10.6 (mostly because they totally screwed up Spaces+Expose+Dashboard). Mountain Lion, although the latest version of Mac OS X, has not fixed the deficiencies that I found in Lion.
The iMac 2010 is specified to only accept up to 16gb of RAM, but I have found that it can take 32gb. That's 8gb in each of the four slots. I ordered two of these 16gb packs when they were on sale a few months ago, and they work like a charm
Ive been bought today Asus HD 7850 when i connect pc and imac 27" with miniDP to miniDP cable (ont he bad iits written ThunderBolt cable 2m <official apple cable) (mid 2010 , mountain lion 10.8.1) after pc is in windoes and imac in mac os x , i press cmd+f2 and nothing happens!!!
Do you have any clues wht to do? Also do you make some setup in catalyst on windows PC before pressing cmd+f2 or some setup before? Thank you very much im passing trough ****....
Thank you for your time....
Your post is difficult to understand. But I can say that DP cables are not the same as Thunderbolt cables. Not sure which you're actually using, because you say it's both...
hey i already ordered this oneThe physical connection is the same, because Apple uses Thunderbolt for Display Port pass through. That is by design. The biggest difference between Display Port Cables and Thunderbolt Cables is that Thunderbolt Cables are active. Display Port cables are just copper, Thunderbolt being active include circuitry not present in Display Port cables.
http://en.wikipedia.org/wiki/Thunderbolt_(interface)
Just purchase a regular Display Port cable and see if that fixes your issue (make sure you buy the right one...)
Should be fine, provided that your 7970 takes Mini DP. I think most nVidia/AMD products use the Mini size as opposed to regular, but I'm not particularly familiar.
One thing to also check is that you have the miniDP cable as the only monitor connection coming out of the video card. If there is another monitor already connected, then it may be using it as the primary monitor, in which case you'd need to change the monitor configuration in Windows after it has started up.
I just use the iMac as the PC's only monitor, so mine involves no setup, works in BIOS and "DOS" mode, etc.
Yes, shouldn't even need to do cmd+F2, the iMac will switch automatically when it sees signal coming to the miniDP port on the back.
I have searched for a while it seems that it won't work but one last hope before I spent money on a new monitor for my gaming pc
I have 27 inc mac mid 2010 with ATI Radeon HD 5670 graphics card.
On my pc am planning to buy asus-gtx670 256bit-nvidia-geforce
Is there anyway to make target display mode.
thanks very much for your fast reply. I have one last question I have been searching for a minidp to dp and in my country I have no luck. would it be possible to use mdp to dvi instead. My video card on pc has DVI port
So to use my imac 27 display (as monitor) for my gameing pc should I start the imac 27 with bootcamp? or is it misleading info
Has anyone tried any other newly released cards lately?
