Well, just got this thing dropped off, and it's better than I ever thought it could be...
Seriously, it's incredible. Spent a bunch of time on the settings, definitely happy with the way it looks now, hopefully won't have to get the windas cable too too soon. Only problem is that the USB ports don't work, but that's not too big of a deal. Also, apparently finding the perfect convergence level is impossible, but I got it close enough!
Thanks Doadea for the instructions on opening the case very helpful. Thanks eclypse for posting your experience of taking off the antiglare layer. I didn't know it was so easy to remove and once I saw your experience I promptly removed mine. My screen is also now perfect. I've been trying to think of a way to fix my scratches or remove the layer for quite some time now. Thank you again.
Heya guys I had a few questions before I go pick up this monitor.
I already have a 21" CRT Compaq P110, I was wondering if this 24" widescreen would be better than what I already have?? I mostly game and just watch movies.
Also which connection would be better BNC or VGA?? If BNC then where might I pick up a quality pair of connectors that would go to DVI???
I finally got around to trying my G520 with the removed coating. Can't say i was that pleased with the result. I tried it with various light conditions and found that even with very dim light the glare was quite prominant on a dark screen. Whereas right now im using my P1130 (with anti-glare coating) in a room with about 5 times as much light and i see only a teeny bit of glare on a dark screen. Plus as more light hits the uncoated screen the black level becomes more and more washed out looking, which does not happen hardly at all with the coating, it stays fairly dark no matter how much light is on it.
I did a little research and found an interesting product called Glare Buster. Its a spray on aerosol anti-glare coating which is supposed to work quite well. It can also be removed easily so theres no risk in using it.
http://www.glarebusters.com/
I don't think i will be ordering the stuff myself since i don't plan on using the G520 anymore but some of you guys might wanna give it a try.
Can anybody give me some actual concrete benefits of using the BNC cables over just a VGA cable? I looked through most of the thread, it looks like the differences are negligible, but would like to heard it first hand from somebody who has tried both.
Wow I never knew the anti glare could be removed that way .. Very cool ..although when we removed the anti glare from a Sony G400 the result wasn't the greatest , the picture had a slightly washed out look to it, hopefully no one here has the same results w/ their FW900.
I've had both on mine. I am running Vista. A good quality BNC has always been better than a Good quality HD-15. That's why a lot of high end monitors have BNC's like the one you have here. I see much better color saturation and contrast when using BNC. Really good cables make the difference less obvious. This monitor deserves a Good cable. I've posted a link for good cables earlier in this thread.
One issue is that BNC does not talk back to the computer so you may have issues with "sensing" the monitor with BNC. Foe me, If I use BNC, Vista keeps switching me to Generic VGA on a Reboot. Then the correct resolutions for 16:10 won't be available as an option. I don't want to use Powerstrip. There may be another work around in Vista for BNC inputs and locking in the monitor type, but I don't know what it is. I never had this issue with XP or 2000. Vista is just too freakin' "SMART" for it's own good I suppose.
I have two "higher quality" DVI-I to BNC cables incoming, so I'll compare it to the low quality BNC Cable + DVI -> D-SUB Adapter solution I'm using right now. One of the cables is supposed to be a high end one, but I'm not holding my breath.
Looks like my screen has an issue thou...
When I turn it on after I get home from work, during the first hour or so the picture becomes blurry a couple of times. Turning it off and on again after a 5 second wait, the picture is sharp again, until a few minutes later it goes all blurry again. Didn't and don't have this issue with my old Eizo, so it's definately the Sony screen and not the graphics card / system thats behaving odd. And clues what might be the cause of this blurryness and how to fix it?
Coming from lunch as of this writing (screen was turned off for around half an hour), it's back to blurry / off / wait / on / wait / blurry again.
Would be interesting to know if this is limited to 2001 models only. Maybe the later 2003 models don't have this issue.
Hmm, the pots having to warm up prior to functioning properly? Interesting idea. Because after my screen is on for something between 45min and an hour, It's working flawlessly. Anyway, I'm keeping an eye out for a 2003 model. Were there produced any FW900 in 04?
:Edit
OK, so I managed to adjust the two focus pots from the outside. Let's see how the screen behaves tomorrow when I'm back again from work.
If you want to tweak focus, too, but don't know if what you found is a screw or a pot - wasn't sure myself - the 6th picture in this posting shows where and what to look for: http://75.126.99.204/showpost.php?p=1030076125&postcount=2321 Thanks to MightyJoe.
Off Topic:
Any clues if and when the search function will be back again?
Anyone know if they make a BNC switch? I'd like to hook up my PS3 and PC to BNC, since that port is pretty much perfect.
Also, for those who adjusted your focus pots through the casing, how easy was it? Any chance of.. .dying if I miss the pots? lol I know where they should be, but I can't seem to see them with a flashlight (HP version).
I still can't decide if I should try it or not... I don't think it would void the warranty with AccurateIT, but who knows.
If I mess with mine, I plan to take it all down. My intention is that at the end of the adjustment to apply a small dap of silicone to lock them back down. Sony thought it was a good idea, so I do also. If it takes such a small amount to make a huge difference in adjustment, this just seems like a good idea to lock the screws back down.
Les
