jbltecnicspro
- Aug 18, 2006
are there even shops or specialists still servicing CRTs?
They're still around. Gotta know where to look. There's one in my city and another in a neighboring city.
By WinDAS COM cable do you mean a legit Sony service part?So I just bought a Z170 board that has an on-board COM port to wire up an external COM connector. Is it possible for me to run WinDAS with this thing and Windows 10 64-bit with my WinDAS COM cable?
so im at a lan party in seattle and i picked up the fw900 on the way and well, the sun was in my eyes and here what I did.
also its here Necessity is the mother of invention. Guy built a CRT antiglare box at a lan party. • /r/pcmasterrace
Vertical? You don't mean the horizontal Trinitron grille wires, right?so I have these two little veritcal line running across the fw900, thier barely visable any idea on how to make them go away?
The WinDAS floating around that most people are using was cracked to work without the Sony ECS cable which is a COM cable with a special TTL chip. I was wondering if that's what you meant by COM cable, but it sounds like you probably have a regular USB-TTL cable. In that case you don't need to mess around with anything on your PC motherboard.
i mean horizontal, and no its toward the middle of the screen, they are barely visable and very hard to see, its almost as if its a scanline, there is two of themand its not the stabilizing wires, i dont think.Vertical? You don't mean the horizontal Trinitron grille wires, right?
Can you spot the stabilizing wires, then? They're about 1/3 and 2/3 of the way up the screen.i mean horizontal, and no its toward the middle of the screen, they are barely visable and very hard to see, its almost as if its a scanline, there is two of themand its not the stabilizing wires, i dont think.
Sounds about right. They're there to hold the aperture grille together at the middle.wait I though the stabilizing wires were at the top and bottom? they barely visable, one is about 2 to 3 inches down from the top bezel from the Trinitron logo, and the other one is about 5 to 6 inches from the bottom of the screen.
I wonder if there is a low latency converter to hook up component cables devices. i'd be interesting to see how consoles look on one of these.
Too bad you had to get rid of them, man. Still sounds like you had a good time.SO boys I have bad news and good news, Goods news I sold both my fw900's for profit and won a 480GB SSD with them at the lan party, bad news after I got them and starting playing on them, dont get me wrong I loved them. However they were causing me to have migraines, and I could see still the flicker at 95 hertz, and cause my eye to strain pretty bad. I havnt used a CRT since I was a kid but Doesnt seem like they agree with me now. Theyre great, its just a shame they were hurting my eyes and head.
why not, it doesn't weigh over 50kg packed and any decent company is shipping that. Plus it's not oversized object...Is that even feasible to ship you think?
Left it turned on since morning and it seems that once every few hours it starts to shake for a moment but overally works well. Going to keep it turned on overnight.
Unkle Vito do you think this is FBT problem? If so, do you have any spare ones?
had the same issue leaving it on all the time helped in the beginning but it got worse and worse, swapping the board eventually fixed it though.
Day 3 and no signs of popping yet. Anyway I think I should replace what is necessary. What do you mean by "board"?
I replaced the entire D-Board
its the one with the with the flyback
