Well for my eyes it is not a placebo effect. Text is now as clear as my lcd. As good as it gets as far as i'm concerned.Going by peeps comment sin this thread I would say the BNC is no better its a Placebo effect esp as most have long thin unshielded tails.
The max for 1920x1200 is 96HZ for the Monitor to be in range.
I'm doing 1920x1080@100hz with a Tri-sli 285's and it is cool. I think it would really shine at 120hz haven't had time to mess with that though and I want the highest rez.. I have to set the depth at the minium and it looks good in left4dead and cod4 and ut3 although the names over peoples head pops out in a weird way and i might be sitting to close to the monitor.1536 x 960 @120 Hz is a neat resolution. Horizontal Scanning Frequency Required (With Estimated Retrace) is 118.2 KHz, the monitor allows 121 KHz in theory.
Please tell us about your results with the nvidia 3D vision
This is a box that supports 1080p/72Hz but it costs $335 : http://www.curtpalme.com/EXT-FULLHD.shtm
HDFury2 has, afaik, gamma correction and an optional BNC connector.
In my former life I would set up corperate meetings and concerts and would set up alot of computers and large plasmas and bnc was always prefered over vga. Would also travel over longert distances without degradation. Also they are all shielded. Data travels over the Center pin and the and the outer screw on ring is the shield. Bayonet Nut Connector FTW!
The cable you link to is the same cheap/nasty generic unshielded at tails that has been mentioned many times in this thread.
If your happy then I'm happy for you but your the only 1 in this thread that has said for sure they see it better.
I have no issues with text on mines at 1600x1000@110HZ (My chosen Desktop RES so DPI is ok for Websites).
There is a Sharpness/Focus pot inside the monitor you can get to from the top air grill.
I had the same problem with Ghosting when I first got mine, it ended up that my cable was not connecting properly to my video card and getting a new cable from mono price fixed the problem.
Also everyone saying BNC cables are unshielded is wrong, they are shielded as every thing travels over the center wire and the thing you twist on is part of the shield (as has been stated many times but apparently people don't get it).
I would temporarily move the monitor or the PC and try without the second VGA cable.
Make sure that every connector is screwed really tight. What helped in my case was to use the other DVI on the videocard and a different DVI-VGA Adapter.
My experience on the matter is:
- Streaking is a matter of cable quality
- Ghosting is a matter of cable length and quality of connectors and signal generator/receptor
So if you see only ghosting, I think the problem lies in the adapters and connections and maybe, but quite unlikely, in the videocard. But I would try the other output.
I just bought another one of these from ebay. I'm on it right now and it has a really bluish look to everything(I have it on RGB color). It's hooked up through BNC but my other one was through VGA. Anybody else have this problem and solved it?
check your bias and gains in color control. i have my bias for all set to 50 and gain at 85 for all.
adjust accordingly of course depending on ur monitor.
Most likely, the issue with this particular monitor is that one (or more) of the guns is(are) going bad and cannot compensate for the others. When this happends, then the monitor will exhibit a color cast. The CRT needs white point balance adjustment, but if during the procedure, the CRT emission tests "low" and any of the gun(s) test "bad", it will never achive proper white point balance, and the CRT has may have reached the end of its life.
However, if the guns and CRT test "good", then the problem is in the A1 board of the monitor, where some resistors and/or transistors may have gone bad and they need to be checked then replaced.
Hope this helps...
Sincerely,
Unkle Vito!
Thank you!For the people that need WinDAS, here you go: http://www.mediafire.com/?4e3gt3mnmjd
They are all set to stock for RGB
You scared the crap out of me! I was almost sure what you described was my problem but then I kept thinking "why would the guns go bad on a barely used monitor", but then again shiz happens so I was believing it. I almost feel like a complete ass for not trying this first and I'm sorry for jumping to conclusions but all I had to do was run the "image restore"(actually twice cause the first run didn't get rid of all the blue, most of it though) and it fixed it. I wonder if this kid sold it to me thinking it was defected? His dad even told me he bought it for him brand new in 03 and the kid barely used it cause he was always gone in college. Or could it still have a gun problem and "image restore" is just compensating?
Btw, the kid has a friggin G520 that was barely used too, wtf what kind of parent just spends that kind of money on something that will never be used? I'm buying it in a week for $100
*Added - I just tried VGA after running BNC all day and there is in fact a difference contrary to what some say. BNC strengths are better color, text. BNC weakness is BAD convergence, PC doesn't recognize the monitor. VGA wins for me although the quality is not quite as good, bad convergence is bothersome and I like my games to have all the res's available.
just ordered a windas cable!
ive had this monitor for more than 3 years now. it is about time i treat it right...
Where did you get it from?
Thanks
Image restore is a "temporary" adjustment solution but it does not fix the issue. If you perform a WinDAS fix, you'll notice that the monitor's true image will be displayed as soon as you click on the "white balance" tab. You'll see the color cast immediately.
How do you know if the Sony CRT has had very little use? The only way to find out how much usage in on a Sony CRT is by performing an emission test by using a Sencore CR7000, and then a white balance adjustment in WinDAS, which both check the luminance (emission) of the CRT. If the CR7000 gives you a "low" emission result, then the tube will have very low luminace and it will have extensive use. If in WinDAS, the CRT adjustment for luminance (while adjusting the white pattern) is between zero (new) and 100 (not that much use), then you have a CRT with "not much use". Any adjustments between 101 to 255 (washed out) are indication of a CRT with extensive use.
Hope this helps...
Sincerely,
Unkle Vito!
it is not a bad fine. It is decent. why dont you just invest in an lcd. It is cheaper and lighter on the desk. it is just a thought.
I wouldn't put it that way.Because LCDs are inferior to CRTs in almost every way.
Rather, LCDs are inferior to CRTs in many ways. To be perfectly fair, LCDs have a lot of advantages too.
You just have to weight them out and get what suits you better. Or get both, like me.
