jbltecnicspro
- Aug 18, 2006
I don't really blame you. LG has gone backward in their support for BFI. Samsung monitors support BFI but not without a high amount of input lag that makes it unusable (like really what's the point?). If I had a fully functional 22-inch CRT like you then I'd still be using it too.Thanks . I truly wish I could move onto the larger OLED screen but it simply doesn't offer enough benefit to ME to make the switch. The only true advantage is screen size and frankly after a half hour on a 22in crt your brain adjusts to the smaller screen. That said, OLED is as close as it gets as a crt replacement but it's simply not there yet for my personal use case.
