pippenainteasy
- May 20, 2016
Yeah, it was worth it for me. Running 1440p Surround is crazy intensive and the 2080 Ti delivers.
You have gsync though, doesn't gsync make it look fine for 40-60Hz range?
Yes and no. G-Sync eliminates the issue of slow downs with V-Sync On, and the tearing of V-Sync off, but still doesn't save you from a choppy experience at low frame-rates.You have gsync though, doesn't gsync make it look fine for 40-60Hz range?
MSI Ventus is back in stock at Newegg. Just picked one up.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814137368
If you have an EVGA 2080 Ti XC or XC Ultra there is a BIOS update that increases the maximum power target to 130%.
https://forums.evga.com/EVGA-GeForce-RTX-2080-Ti-2080-XCXC-Ultra-BIOS-Update-m2858793.aspx
Unfortunately, the Ventus line is the lowest rung on the MSI lineup its essentially the old "Armor" series, I would have passed on this one.
That is the one I am considering. I need something to fit in my case ....
I am waiting till MC has it.
