If you Google it, you'll see it's been done, even benchmarked
http://www.xbitlabs.com/articles/storage/display/kigston-hyperx-ssd-raid0.html
But it sounds like you are better of getting a bigger SSD, especially because you loose TRIM with raid enabled on SSDs.
Intel just released drivers for TRIM support for RAID. Hell... they even have a thread about it here.
http://hardforum.com/showthread.php?t=1707372&highlight=intel+trim
how crazy is it to have 2 ssd's on raid 0, is it a crazy thing to do or is it ok?
What I wanted to know is, do ssds in raid function/last long enough? I heard that ssds don't last in raid??
Ya, expensive and they take up PCI-E slot(s) that may be needed for gpu's etc.
anyone suggesting a pci-e ssd instead of raid0 is ignoring that pci-e ssds are nothing more than raid0s done for you
they're good, but the raiding of your own ssds allows for much more flexibility
Not necessarily. The main advantage of a PCI-E based SSD is that they support TRIM.
Also, I don't know how other PCI-E ssd drives work, but certain revisions of the OCZ RevoDrive X2 allow you to choose if you want RAID 1 or RAID 0 or JBOD.
Additionally, the Revodrive 3 X2 (X2 = 2 ssd's on the PCI-e board) has read speeds at ~1400mb/s which two SSDs in RAID 0 can't touch (though most consumers won't have a need to utilize such speeds).
A 240GB Revodrive 3 X2 is about $430.
The regular 240GB Revodrive 3 (single ssd on PCI-e board) goes for $300 and reads at about 900mb/s which is about the same as two regular SSDs in RAID 0--plus you get TRIM.
PCI-Express SSDs now seem like a viable option.
The big negatives with the Revodrives, in my experience, is that they add heat to your system (whereas SSDs virtually add none) so OC'd systems may not take to them well. The Revodrive X2's specifically give off significant heat.
And, of course, taking up a PCI-Express slot itself is generally viewed as a negative, though I personally never use all of my PCI-Express slots.
Getting Windows to install the OS on a RevoDrive can be tricky. It took me a couple hours to get the Windows Setup environment to load the drivers correctly.
If you're willing to spend the cash on two SSDs in RAID 0, then PCI-e SSD drives are worth considering.
Does RAID 0 still has the consideration that if one drive fails, you lose all data irrecoverably, having to go back to your backup?
Would performance of two smaller SSDs in RAID be meaningfully better than a single large one?
Honestly, why don't you read a little?how crazy is it to have 2 ssd's on raid 0, is it a crazy thing to do or is it ok?
Next question I would ask is: "Is it worth it?"
Personally I'd choose more ssd space over an even faster ssd setup unless you have particular large files you move around all day.
