generallee989
- Dec 27, 2011
Hello All,
I just built my first Watercooled system and am now nuts about this stuff and feel that its not enough. I was able to take my i7 870 to a 4.2GHz stable clock with only putting out 40*C under full load for 8 hours.
Now i am going to get a little extreme with this IMO. I want to do this setup all internal.
I will be using:
DD Water Box Plus
2 x Black Ice GTX Xtreme 120 Radiator (one for each loop - Push/Pull system)
1 x Koolance VID-AR697 Radeon HD6970 / HD6950 VGA Liquid Cooling Block - Rev 1.1
4 x Koolance RAM-33 Ram Liquid Block
1 x Danger Den MC-TDX Liquid Cooling Block
1 x EK ASUS P55 Series Full Board Cooling Block Kit - Acrylic
2 x Phobya Balancer 150 Reservoir
2 x Danger Den DD-CPX Pro
2 x Feser One Non Conductive Cooling Fluid (1 UV Acid Green / 1 Blood Red) or (1 UV Invisible Blue / 1 UV Pink)
Basically, I will have 2 loops. 1 will be through the 120 Rad, Reservoir, Pump, Ram, GPU.
The other through Rad, Reservoir, Pump, CPU, Chipset.
Does this sound like it will work or is it not enough radiator?
Thanks all for the input.
I will be using:
DD Water Box Plus
