$1600 Build Review
hacktor2
This will be a gaming rig with general surfing, etc. BF3, Diablo III, any newer games (been out of the PC gaming world for awhile) plus the older games like counterstrike source. All at the highest achievable settings.
$1600. Shipping not included.
Minneapolis, MN. Micro center is down the road.
Case, Motherboard, CPU, video card, RAM, PSU, SSD, would like a blue ray and an additional HDD for storage.
Monitor, keyboard, mouse.
6) Will you be overclocking?
Mild OC. Nothing crazy. Everything will be on air cooling.
7) 7) What is the max resolution of your monitor? What size is it?
27.5 viewable" 1920 x 1200.
Within the next month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SATA 6Gb/s, USB 3.0, SLI/Crossfire option would be nice.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes. Win 7 Pro 64-bit
My build:
SAPPHIRE Radeon HD 7970 11197-01-40G Video Card
$479.99
ASRock Z68 Extreme3 Gen3 ATX Intel Motherboard
$121.99
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
$89.99
Seagate SV35.5 2TB 3.5" SATA 6.0Gb/s Internal Hard Drive -Bare Drive
$159.99
Antec Three Hundred Black Computer Case
$54.99
OCZ Vertex 3 VTX3-25SAT3-240G 2.5" MLC Internal Solid State Drive (SSD)
$279.99
Intel Core i5-2500K 3.3GHz LGA 1155 95W Quad-Core Desktop Processor
$219.99
ASUS Black Blu-ray Drive SATA Model BC-12B1ST/BLK/B/AS
$57.99
OCZ Fatal1ty 750W Modular Gaming Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom
$99.99
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 120mm sleeve CPU Cooler
$29.99
Grand Total: $1,594.90 Thoughts? Comments?
There is an i5-2500k for $160ish at MicroCenter. Probably check that out instead of getting it a newegg.
$121.99
Not a good choice since AsRock's Z68 mobos only come with a 1-2 year warranty and their quality is ver inconsistent:
http://www.hardocp.com/article/2011/12/07/asrock_z68_pro3_lga_1155_motherboard_review/
So I wouldn't bother with an AsRock Z68 mobo.
Microcenter will knock $50 off any Z68 or Z77 mobo if you purchase the 2500K or 3570K at the same time. So hrab the 2500K or 3570K and the Gigabyte GA-Z77X-D3H or Gigabyte GA-Z77X-UD3H motheboard and you'll be set.
$159.99
AFAIK, those are meant for surveillance systems and such. As such, I don't think they'll work with computer hardware. I recommend this hard drive instead:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145473
In fact, buy it today and you can take advantage of "$20 off w/ promo code HITAHD53, ends 5/4" deal for that Hitachi drive.
$54.99
Not a good choice since it's relatively cramped and has little to no cable management. I recommend these cases instead:
$50 - NZXT Source 210 Elite Black ATX Case
$50 - NZXT Source 210 Elite White with Black Front Trim ATX Case
$279.99
Not a good choice for three reasons:
1) It's a Sandforce based SSD so it does have a higher chance of issues
2) It's from OCZ whose customer support is pretty crappy
3) This equally fast but higher quality Crucial m4 SSD costs $30 less and has 16 extra gigs:
$250 - Crucial M4 CT256M4SSD2 2.5" 256GB SSD
$99.99
Not a good choice for a PSU. If you need/want a modular PSU, I recommend this:
$90 - SeaSonic M12II 620 Bronze 620W Modular PSU
If you don't need a modular PSU, I recommend this PSU deal:
$90 - Corsair 750TX V2 750W PSU
