hm so anyone knows a good 24 16:10 monitor thats not expensive
crowat
So I don't get it. How are PC users not getting the shaft by reducing the resolution from 1920x1200 to 1920x 1080. Isn't the viewable screen smaller by some 120 pixels? ...
QFT. 16:9 is a reduction in screen resolution from equivalent 16:10 resolutions. It is 100% a means to cut production costs to sell monitors that have less vertical resolution. That's it. If you like the aspect ratio of 16:9 better, then that's your prerogative, but some of us don't like the fact that the LCD market is being invaded by monitors that have less resolution than than equivalently sized monitors used to have in 16:10. QUOTE]
there is the oddball resolution of 2048 x 1152 used on the Acer B273HU and a few Samsung and Dell TN panels ranging from 23" to 27". They keep the 16:9 aspect ratio, but actually offer "higher" resolution than 1920x1200. Now instead of losing 120 vertical pixels the user loses "only" 48 pixels. This oddball resolution comes with a slight price premium over 1920x1080 panels. The reall added benefit is that it is pretty close to the theoretical maximum resolution that a single link DVI or VGA connection can output at 60Hz.
A common use for real screen state is massive multitabling online poker. A 30" LCd can manage 16 tables on most Pokersites, and a tipycal 1680x1050 20" manages 12 tables at the same time , but costs about 1/6 of the 30" price. I am yet to discover if the 2048 x 1152 resolution can manage 15 tables or not, but if it can it would be a good argument in favor of the 16:9 aspect ratio.
Afetr i sold my Acer 2616w, a 26" 16:10 VA Panel with 1920x1200 to use "only" a 30" i am disinclined to acquire most if not all of the offers in the market today: cheap TN panels with lower resolutions and screen sizes.
For massive multitablers poker palyers i recommend start with the cheaps TN 20-22" they can afford, move to dual 22" and then to dual 30". The real screen state gained from 1680x1050 to 1920x1080 isnt worth the upgrade fro poker players, but if the move is to 1920x1200 or 2048 x 1152 ...
16:10
good: it's taller
bad: it's not as wide
16:9
good: it's wider
bad: it's not as tall
After reading for hours on the web (my eyes, them burning) I still don't know how to face this dilemma: I want a 24 inch screen for both the PS3 and the PC and I still can't figure out what is the best to get. Some people say a 16:10 will make things look fat on the PS3, and recommend the 16:9 instead, others say get the 16:10 because you'll have more space.
I'll be using both the PC and the PS3, in the PC I'll do the occasional non-intensive Photoshop work and some writing and website maintenance, so I do wonder if I really need the extra 120 pixels at the bottom... and I just don't want to compromise my PS3 gaming. As far as PC gaming, my PC is old and I don't do much in the way of it, except for the occasional old revisit to an old game.
And I finish the post again uncertain on what to get based on what I use it for.
I wasn't comparing my 24" to the old 19", just stating what I upgraded from only. I'll admit, its redundant.Are you following?
100 times repeated already:
1. 16:10 vs 16:9 comes from misunderstanding of the same diagonal trick and is limited to that. Namely: 24" 1920:1200 vs 24" 1920:1080; 23" 1920:1200 vs 23" 1920:1080 with a few more isolated examples. That's all!
2. The discussion grew from the necessity to refute the filth marketing attack (tons of technical absurd about 16:9 "advantages" that is lie).
3. It has been made clear that 1920:1200 is a higher class over 1920:1080 of the same diagonal as far as size/resolution is concerned. It's a fact that is not discussed any more.
4. Again: "preferences" are not discussable. You prefer higher class full resolution 1920:1200 monitors, someone else prefers to save on smaller and cheaper 1920:1080.
Threre is no sense in discussing that.
5. Your example is out of scope (actually you are spamming the thread). No one in his right mind is going to compare 24" with a 19" dwarf whatever format they have.
albovin, Rogue71 didn't mention that the p2310h is a 23" 1920x1080.
You don't have to apologize.
You stated that people have different opinions. This forum is large enough to accomodate even this fantastic dicovery. No problem. But we don't discuss opinions. 2x2=4 - what is your opinion?
What I am trying to remind you: 1920:1200 is larger than 1920:1080 of the same diagonal. That is a technical fact, not an opinion. We can use different words: "larger", "superior", "higher class" of resolution/size, etc. Whatever you like.
That's the fact.
Then opinions go.
Someone prefers "larger", "superior", "higher class" of resolution/size, etc.
Someone prefers to pay less for ""smaller", "inferior", "lower class" of resolution/size, etc.
There is one reason, and only one reason that I would think that 16:10 ratio would give you any benifits at all. That is if you like to look at two windows SIDE by SIDE. That is because there is a minute increase in the amount of horizontal space on the screen in which a second widow could take advantage of.
Have you seen monitors you are talkinfg about?
This is a Hor+ game:
Same FOV!
