15" 1440 resolution?
Discussion in 'Displays' started by eneq, May 1, 2012.
  1. eneq
    eneq Limp Gawd
    144
    Aug 7, 2009
    Hey
    Is anyone aware of a 15" LCD monitor that has a horizontal resolution of 1440p? I am trying to achieve a PLP setup with a 27" 2560x1440 and I am having a hard time to find any...
    /Q
  2. KrylonArt
    KrylonArt [H]ard|Gawd
    1,492
    Oct 31, 2007
    I think the only time I have seen that is in the 15.4" Apple MacBook monitor, I know that EVGA has the InterView dual 17" with 1440x900 resolution though. You might be able to mod some of the MacBook replacement panels if you can figure out a way to mount them and have the technical knowledge.
  3. eneq
    eneq Limp Gawd
    144
    Aug 7, 2009
    Yeah, I have been thinking about that as a last stop measure. Its a bit tricky to put a laptop panel into a monitor setup due to controller cards, power etc. Its doable but tricky and expensive...
  4. cvgd
    cvgd Limp Gawd
    421
    Mar 20, 2011
  5. eneq
    eneq Limp Gawd
    144
    Aug 7, 2009
    Thanks, that was what I was afraid off. Ah well...
  6. eneq
    eneq Limp Gawd
    144
    Aug 7, 2009
    Ok seems to be doable, with a matching panel+LVDS controller it seems quite straight forward. The biggest issue is to find such a pair, however since I am ok with buying them both new it should be easy.
    Of course cost wise it'll be around 100 for the panel+20-30 bucks for controller card+power brick, then in addition one needs a mounting frame so it'll come out close to 200 bucks for one monitor.
    Probably easier to go 30"+20" sides, just need a good 30" monitor...
  7. suiken_2mieu
    suiken_2mieu 2[H]4U
    2,879
    Apr 7, 2010
    I'm selling a Dell 3007wfp for $675 shipped if you care.
  8. eneq
    eneq Limp Gawd
    144
    Aug 7, 2009
    Thanks for the offer and Ill keep it in mind but atm im tossing different ways on the matter. Just bought a 27" would be silly to jump ship so soon since I am very happy with it.
    /Q
  9. nickchong
    nickchong n00b
    1
    May 10, 2012
    Hi guys, hope this might help anyone looking for a PLP setup with 27" 2560x1440
    i have the imac 27" which i connect to my pc as a display.
    to flank them i use 15.4" 1440x900 laptop lcd replacements, they fit perfectly and more over the bezel is super thin. thinner than any other screens. almost non existant. Of course there will be some colour differences but the controllers allow you to adjust the colours like a regular display so hopefully that will get you close to your 27" screen. My apartment is small hence a plp setup works best. otherwise i would have gone triple 27". only gripe is finding a way to mount the monitors . i have them rested on my bose speakers and held in place with blutack like sticky stuff. bought them off ebay, called black magic.
    http://www.ebay.co.uk/itm/Laptop-screen-B154PW02-15-4-LCD-PANEL-Laptop-s...
    to connect the lcd screens to the computer i bought this
    http://www.ebay.co.uk/itm/Compatible-R-RM5251-LCD-Controller-Board-Kit-D...
    just tell them the model of lcd you're using and they program it for you. you will also need a psu unit which they sell. everything costs about £100 per lcd.
    Displays: 27" imac + 2x 15" 1440 x900 laptop replacement screens
    Display Config: PLP
    GPU: sapphire hd 7870
    Processor: i5 2500k
    Case: silverstone sg05
    [​IMG]
  10. eneq
    eneq Limp Gawd
    144
    Aug 7, 2009
    Seems the ebay posts are gone, can you pose the sellers information instead or a link to their ebay site?
    Great looking setup as well and it cost less than I thought it would, good work!
    /Q
  11. austinpike
    austinpike Limp Gawd
    199
    Oct 26, 2011
    freaking impressive, nice job!
  12. suiken_2mieu
    suiken_2mieu 2[H]4U
    2,879
    Apr 7, 2010
  13. USF-Nealio
    USF-Nealio Limp Gawd
    373
    Jan 18, 2012
    I'd love to see a build log or at least more information/pictures of how you did that. that simply looks amazing, and being nearly bezel-less looks great!
  14. Xeth
    Xeth [H]ard|Gawd
    1,624
    Apr 6, 2007
    How did you get PLP to work with Eyefinity/Surround?!
  15. suiken_2mieu
    suiken_2mieu 2[H]4U
    2,879
    Apr 7, 2010
    SoftTH and Windowed Mode
  16. KrylonArt
    1,492
    Oct 31, 2007
    Try searching Ebay using these terms:
    B154PW02 15.4" WXGA+ LCD Screen ($60 each)
    R.RM5251 LCD Controller Board Kit ($30 each)
