$1400 Gaming RIG!
try n c i x.com (minus spacing), they're good at stuff and may have a retail location near you.
You can unlock non-ref 6950's
Where is the list?
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$70 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$106 - Lian Li PC-7B Plus II ATX Case
$110 - Fractal Design Define R3 Black ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$165 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$220 - Corsair Obsidian Series 650D ATX Case
$220 - Cooler Master ATCS 840 RC-840-KKN1-GP Full Tower ATX Case
$230 - Silverstone FT02B ATX Case
$220 - Lian Li PC-A71F Black ATX Case
$290 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
$330 - Silverstone Temjin SST-TJ07B Full Tower ATX Case
Easy question: I need a DVD burner with DVD±R/±RW
Can someone choose the best one from this list
http://www.memoryexpress.com/Produc...ME)/DVDDrives(ME)/Default.aspx?Sort=Price_Asc
Just go for the cheapest SATA DVD burner you can find. They're basically all the same at this point
Ok I've finished building the PC and turned on on the first try :)
BUt I have some questions, since Im using a SSD, I read using AHCI is better than IDE.
How to change to AHCI mode?
On my mobo I went to integrated peripherals>
There are 2 options that can be changed to AHCI
1)SATA Configuration-SATA mode
and
2) onboard e-sata configuration-onboard e-sata controller mode
Which one do I switch to AHCI?
Also according to my mobo my CPU is idling at 44C. Im using a hyper 212+. Doesn't this seem a bit too high? I think maybe I used too little thermal paste (arctic silver 5) or didn't screw it tight enough?
I used the 3 line method
Also when I was tightening the screws for the 212+ I accidentally bumped it and it kinda swiveled a bit. It was not stuck in place.. is that bad..?
Hi, I posted here a while back, but now I am ready to buy the parts:p
1) Gaming, movies, internet
2) $1400, not incl. tax and shipping
3) Canada
4) New build, will need all the parts
5) Might be reusing optical drive and media card reader, not sure yet.
6) Yes
7) 1920x1080 on a 23"
8) Next week
9) xfire, optical, usb 3, sata 6
10) I have a copy of win 7 64 bit
My build so far:
Thermaltake TPX-775M Toughpower XT 775W Power Supply
MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core™ i5-2500K Processor, 3.30GHz w/ 6MB Cache
Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
Crucial RealSSD C300 CTFDDAC064MAG-1G1 2.5" 64GB SATA III MLC Internal Solid State
Western Digital 1TB Caviar Black 7200rpm SATA III w/ 64MB Cache
XFX HD-695X-CNFC Radeon HD 6950 2GB
Cooler Master 200mm Red LED Fan
COOLER MASTER Hyper 212 Plus
Total is just under $1400.
I went with the WD black because it's cheaper than the samsung f3.
I heard good things about the zalman cooler, and it looks relatively easy to install. I'm a first time builder so keep this in my mind. I also like the led.. I don't mind paying a bit more for it, unless there's a better alternative. I'll only be doing mild OCing.
Thanks!
3 quick points though I've not read the thread. edit: lol, I'm too late you already built it
1) You may want to bump up the Watts on your PSU to 850 in case you plan on slapping in another video card down the line.
2)I would consider getingt a cheaper 40gb SSD for the boot drive and spend the difference on faster RAM. Win 7 doesn't need more than 40gb, unless you plan on adding things like Adobe suite or PC games to the SSD, 64gb is more than needed.
3)Western Digital Caviar Black is a really great hard drive, however it does not work in RAID, so if you plan on adding more hard drives in a RAID format later you would be better off getting something else.
Just finished building it.. but could you answer these questions
and
Switch both to AHCI.
As for the temps, there's three variables that haven't been accounted for: The airflow layout and cooling in you case, your ambient temperatures (the higher it is, the higher the temps inside your PC, and that AS5 takes about 150 to 200 hours of the PC being on to fully "cure" or achieve the optimal cooling.
Then again, if you're using the Fractal Design R3 case, those temps may be normal considering that the Fractal Desgin's main goal is noise level whereas cooling is of secondary importance.
ok so right now i have:
SATA Configuration:
SATA Mode: AHCI Mode
SATA 1 Hot plug enabled (SSD is connected to SATA 1)
and sata 2-6 are disabled
and
Onboard E-SATA Config
ONboard E-SATA controller mode [AHCI]
that sound right?
Enable SATA ports 2-6 and then it'll sound right
I bought the scythe kaze jyuni high air flow and it is really loud.
Is there any way to control it so that it only intakes more air when needed?
The kaze fan should be FANIN0
I have another problem lol
My front panel audio jack does not work. But my front usbs do work
I messed around in the realtek hd audio manager but could not get it working
It only talks about controlling the cpu fan, nothing about case fans :S
Case fan? Oh then what I said earlier is your best bet: An actual fan controller.
Did you hook up the front audio cable in your case to the motherboard?
I'm planning to play DA origins, DA2, borderlands, crysis 2, AC Brotherhood, GW2, BF3, most of the latest titles.
I can get the thermaltake for $80AR. Quality wise it's great right? [H] gave it a silver medal recommendation thing so its fine?
http://www.tigerdirect.ca/applicati...tails.asp?EdpNo=6624663&csid=ITD&body=REBATES
Is the 212+ easy to install? I have zero experience building computers..
I'm looking for a reference card so I can unlock it. Haven't found any from those companies.
Yes its sata 6
http://www.memoryexpress.com/Products/PID-MX27676(ME).aspx
and thanks for the super quick reply
FYI for anyone interested.
In researching this cooler, I found a good Youtube video
on installation.
http://www.youtube.com/watch?v=8l2h0nYGAdk&feature=player_embedded
Looks easy as pie.
