2.8GHz base and 3.2GHz boost were the clocks of the first gen engineering sample of the 1800X: 1D2801A2M88E4_32/28_N. The second gen engineering sample, 2D3151A2M88E4_35/31_N, increased clocks to 3.1GHz base and 3.5GHz boost.
This Zen2 sample mentioned in the OP is a second gen engineering sample.
2D3212BGMCWH2_37 / 34_N
2 = Second gen engineering sample
D = Desktop
321 = ?
2 = Model number
BG = 105W
M = AM4 socket
C = 12C
W = 12x 512KB L2 + 32 MB L3
H2 = Steeping
37 = 3.7GHz boost
34 = 3.4GHz base
And has stated that there will be fill backward compatibility as long as the Mobo maker releases a bios update for it.If I have to replace my Crosshair 6 I am going to be pissed. This board has been great to me. I am not sure if the backwards compatibility will go all the way to X370 even on the 8 core chips.
Top end desktop parts like a potential 12C or 16C Ryzen would be low volume high price parts too. Likely in the $1000 range. Most Zen2 CPU's sold will probably be 8C or less parts and the 8C versions could be made up of 2x 4C dies that were scavenged and tied together via the IO die. Yields on raw Zen2 dies from the fab should be pretty good as well. The dies are actually fairly small (comparable to phone SoC's) too so that should help with yields a fair amount.Consider that bining of chiplets could produce 8 good cores per chiplet, but wouldn't they prefer to use those on EPYC high margin parts first?
TR was a super low volume prestige/halo part + Zen2 based TR is going to support lots more than 16C's and have more memory channels to feed them. There is no real risk of cannibalizing TR sales with 12C and 16C desktop Ryzens.but why canibalize Threadripper sales?
They are but they're not going to be missing out on any profits by pushing the limits of core counts on the desktop or prosumer market at all.They are focusing on the datacenter where the margins are.
So there's rumors of a 16 core am4. Is there any credible evidence?
I could see bumping my b450 to a 12 or 16 and my x399 from 16 to 32 or 48 or whatever is the next 900 chip.
would not recommend putting the 12/16 core on the b450, most of them barely handle the 2700x at max boost, highly doubt the vrm's will handle the 16 core part. also wouldn't surprise me if the 12/16 core parts get locked down to x570 only due to VRM requirements.
Remember they are 7nm. Power required is gonna be much lower.
But you're probably right.
The 2700X is officially a 105W chip. The two 12C models are supposed to be 95W and 105W chips, and the rumored 16C models are supposed to be 125W and 135W, so sirmonkey1985 point is relevant.
Ok, risking sounding like a debby downer here. Am I the only one who doesn't see the need for all these cores?!? I mean I have a hex core Ivy-E currently; before that a hex Sandy-E. I fully plan on going to either a hex or octo core Zen 2, for sure. I'm itching to get back to AMD. But 12, 16 cores or more? All I use my custom rig anymore for is gaming. I simply can't see needing more than 8 cores at this point for gaming.
You're right more than 8C is overkill....RIGHT NOW.Am I the only one who doesn't see the need for all these cores?!?
And realistically probably for the next couple of years.
The thing is as the new consoles come out (rumored to use 8C/16T Zen2's) and as these new higher core count CPU's become more commonplace developers will actually start to make use of them. Yes even in games.
I think the term "future proofing" is more than a bit played out at this point in the PC world but a 12 or 16 core Zen2 at 4.5Ghz or more would certainly help keep your system relevant without further CPU upgrades for quite a while.
Most of us dont need more than 6 cores. But for some people its the greatest time saver since microwave ovens.
People have different workloads. My workload is shooting people in the head and watching porn.
I benefit from moar cores. I do a mixture of so much different shit, it's nuts. Video encoding. Rendering. Audio production & DJing. Gaming. Compiling.
It's because I'm a UI developer by day, a trance DJ and producer by night, and I dabble in 3d work for fun.
What kinda songs do you like/play sir?![]()
