Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
And if you install Windows Vista or 7 in a system with multiple hard drives, the system reserved partition (used for recovery/bitlocker/image index) will be placed on a drive that does not contain the OS partition. You can manually make it so that the system reserved partition is placed on the OS drive, but you must disconnect all other drives when installing Windows.
