CPU: E8400
MOBO: Model #: GA-P35-DS3L (Gigabyte DS3L)
HEATSINK: Tuniq Tower 120
RAM: Model #: F2-6400CL5D-2GBNQ (G.SKILL 2GB DDR2 800)
PSU: Corsair HX520
OS: XP 32bit
Coretemp during 32m SuperPi, 47c low, 66c high, around 59-61 average near the end.
4.41GHz @ 1.6 bios vcore. There's nothing higher except 1.8 and 2.0.
Also, I'm thinking about getting the Mushkin 4gb DDR2 800 Ascent ram to hopefully get TF2 running at 100fps constant, even in 24 player firefights.
Can't seem to keep 100fps even with low settings at 640x. Using DX8 instead of DX9 doesn't seem to help much either.
I'm turning HDR and Motion Blur off because I've heard CPU power whereas the other things are just GPU? I'm not sure, if anyone can shed more info, thank you.
1) Is it the high vcore itself that causes degradation or the heat?
2) I've seen reviews where the Mushkin Ascent runs at 1100mhz so would it be possible to push the CPU further and even if I can't, think the upgrade will help the TF2 FPS?
edit: 100fps is only useless if you play on LCDs. -dxlevel 81 is a launch cmd that puts tf2 into dx8 mode for higher fps.
PSU: Corsair HX520
OS: XP 32bit
