I just did this with mine, starting out slowing doing clockwise circles=nothing, then really fast and it was slight. So no its not the same for everyone. Also, other variables can play in this including GPU Drivers displaying the image. Basically it comes down to if you are really looking for something to bitch about with these monitors and you have the time to do all these tests, sure you will find something wrong if you are looking for it.
I also played the games the poster mentioned. Nah, its got to be driver related on his end.
I have a 8800GTS 512(G92) with 197.57(last beta before the v256 drivers) on Win7 x64. Pretty average, besides they do the same thing when I hook them up to my laptop and netbook.
The problem is however Samsung implemented Overdrive on this monitor, because everything is fine when its disabled.
Also I swear I wasn't looking for it , I just know how things should look and when something is off then I tend to notice it.
http://www.tftcentral.co.uk/advanced.htm - Lots of info on Overdrive and other LCD Enhancements here.
I'm mildly curious about this 'magic view' feature - does it fix the major failing of TN? i.e. can this monitor display a solid colour from top to bottom of the screen without exhibiting a visible colour shift? Usually with TN I see bright colour near the top, but the colour fades dramatically at the bottom - so even at normal 1.5'-3' viewing distance I find TN unpleasant.
The MagicAngle doesn't fix the average TN color shift when viewing the monitor head on. Instead it's for extreme viewing angle changes, like when your standing above the screen.
if i type really hard / tap buttons on my desk the screen shakes, is there anyway to stop this? i thought it might be the stand but the part thats moving is the top were you can lean the screen back.
btw what was that thing at the bottom when you install it /screw and then the coin thingy that you have to flick to the other side. ?
You have to align the monitor into the round base (it only goes in one way, so pay attention to the alignment), and then screw it tight using the 'coin thingy'.
