Do you have a PS3 to try this with?
@merid14: Do a quick search on YouTube for "ps3 monitor" ...or keywords along those lines, and you'll find a ton of videos showing its possible. I'm also searching for a monitor to use for PS3 gaming, I found the ASUS VE278Q and the Dell U2311H if you wanna check those out.
However, just like DCmod said, the monitor you choose has to be HDCP ready/compliant so the image can be seen. Most monitors today are HDCP compliant. Also like DCmod said, HDMI-to-DVI will work.
DCmod, can you confirm the HDMI-to-DisplayPort? ..I've read that won't work, like for example on an iMac, you need to purchase a $150 adapter that allows HDMI to be converted to a DisplayPort signal.
It's not so much that monitors can't do it, but I think both Vega and I thought the ZR30w had no internal scaler, like the LP3065, meaning it can ONLY display 2560x1600 or 1280x800 which the PS3 doesn't output but that appears not to be the case.
