What drivers from Zotac's site are you guys downloading?
I just got the latest IGP / chipset drivers directly from NVIDIA's site.
Would the Intel E3300 will work on this board? Zotac's CPU compatibility list (last updated February ) doesn't list it. But on the other hand, it doesn't list the E5300 either and that seems to be a popular choice going by forum postings.
I'm looking to setup two of these systems, would be an unfortunate surprise to buy the parts and find that it doesn't work.
That was probably the Xbit Labs review on the E3x00. Those second-generation 45nm dies are a boon to low power PCs. I have an E3200 running undervolted on an ASRock G31 board, and according to IES (ASRock's Energy Saving app), that little slugger runs as low as 5W (including VRM power, I believe), and load power usually tops under 10W.True, but my intention is to build a very low power system. I can't remember where I saw it, but one review put the E3300 at ~10-12W less than a E5200 or E5300.
An important factor in a low power system is the PSU. You don't want to be idling at 30W DC if your PSU's efficiency has gone down the drain. There aren't many good low-wattage high efficiency PSU. There is a Seasonic 330, if I remember right.
Unless, of course, you count those ultra-rare Dell 200W bricks.And the best one is 150W, but no AC/DC adaptor provides that much on the 12V line. (108 is the highest I recall right now).
If anyone cares, even with an E5200 and this board, I'm using the 150watt Pico PSU but with an 80watt AC Adapter.. I've never had stability issues with it... and the stock intel cooler keeps the E5200 quite cool.
My issue is the GPU running hot actually... my M350 case is too small and doesn't give the GPU any room. So I'm most likely going to wait for the LianLi PC-Q09 which is slightly bigger (200mm x 98mm x 200mm) vs (192mm x 62mm x 210mm) It's really only slightly taller but it gives room for a slimline drive, is all aluminum and sticks a 2.5" drive and slimline DVD underneath the motherboard tray and gives an 80mm fan for the motherboard as well. Otherwise I might be dumping the mini-itx al-together and just get a micro-atx with a bigger case that I can make silent. If the GPU didn't run hot this would be the perfect case.
First of all, let me clarify that I don't own a Zotac motherboard.I think it's called VRM? 2 of them burnt and smoked. I believe I saw somewhere that's pretty durable and usually something else die before it dies.
That being said, I can shed some light on how VRMs (Voltage Regulators) work, and how that can equate to a burnt motherboard.
First of all, VRMs are responsible for passing and regulating current going from the PSU to the CPU (and other components like memory slots). Each voltage regulator can handle a set amount of current before risking malfunction. And, depending on the CPU TDP, more or less regulators are used.
For instance, the tiny Atom boards only need one such regulators for the CPU, since the maximum TDP is only 8W. On the other hand, 95W TDP quad-cores need at least three good ones, usually 4. And that's only for stock settings, OCing greatly increases current flow to the CPU, hence the copious amount of regulators present on top-tier boards (though some of them are just for showing off... I've seen videos of a single VRM pack (8 or 12 phases, I think) on an EVGA board powering two CPU sockets at the same time - power cables were run from the VRMs on one motherboard to the VRM pinouts on a second board, which had been stripped from the VRM pack - without breaking a sweat).
I don't really know how many regulators that Zotac board has. I'm assuming 4, given CPU support and the utter lack of space on mini-ITX boards. That means pushing a quad (especially if it's a B3 Q6600) will hit normal VRM limits much faster than with smaller (and less power-hungry) CPUs. Which may cause them to go bye-bye without warning.
There are also other considerations to be made, like Anandtech recently uncovered on (lack) of socket pressure on the CPU, which may cause premature CPU or motherboard death, including caused by over-taxation of the VRM modules. However, that's not really a known socket 775 problem...
That being said, you might have gotten a dud. The point is, if you want OC and mini-ITX, I don't really think you have ANY other option, since the only other non-industrial mini-ITX socket 775 mobos around are from Intel, and we all know just how unfriendly Intel BIOSes are, especially if you want to OC...
Cheers.
Miguel
You're welcome.Thanks for reply.
If the board is really a 3 or 4-phase one, then that bump can drive the current draw above maximum recommended limits. Anandtech (if memory serves me right) has dedicated some time to that subject, especially after the whole P55 motherboard (and CPU) blowup. Granted, it's not socket 775, but the same principles aply.It was actually G0 and VID of 1.225. I didn't think I was pushing that much at 3.15GHz and all the other mobo Ihad shut itself down or not even power up if it was too much.
I can't help you there, either.How are other people who has Q6600 OC theirs? and how long have you been running with it?
You're welcome.
Of course, as I said, I don't own that board, and I'm not an OCer either (though I own an X48 Asus board... Yes, I know, overkill).
Not only I don't own a motherboard even remotely similar to yours (closest one is an Atom-based Intel D945GCLF), I also don't own a quad, only single and dual-cores (Atom 230, Pentium D805, E1200, E4300, E3200 and E7200). Nor do I OC (I love undervolting, and overclocking is usually not undervolting-friendly... lol)
I might upgrade to Nehalem this year, let's see if I'm lucky...
Cheers.
Miguel
To be fair, Zotac is not to blame here. The problems I described are common to just about any motherboard.more i hear from you,less i want to try Zotac again lol.
Usually VRMs are spread around the CPU socket. They may consist of black cubes with a letter and a number on them, or a long strip (only for digital voltage regulators, there are only a couple of boards that use this). Generally speaking, the VRMs are the repeated elements around the CPU socket, and are usually next to capacitors.where are the VRM's located on this board? can you just added small copper heatsinks to them to increase reliability?
Yeah, that's actually very nice. In my setup, my E7200 can't even be bumped to 333MHz without having to kick voltage up a notch, and even then it starts to double-POST and randomly hang in Windows (a.k.a. insta-reboot or insta-freeze). Not to mention the ultra-finicky LAN drivers that absolutely HATE having any kind of filter applied over them (like cFosSpeed's filter driver), which also causes random hangs/reboots... All this on an Asus P5E Deluxe motherboard... Sigh...Well Intel's mature 45nm process will sometimes allow you both: I have E8400 pushed to 9*400 (not fantastic, I know, but it's better than a kick in the teeth) running slightly undervolted... That gives you a pretty decent CPU at relatively low power.
Rightmark's CPU Clock Utility, as other such utilities like CPUGenie, can be used with ANY motherboard.Regarding undervolting. its possible to undervolt the board, im now running my E8600@ 1,10V instead of 1,25V gives me 10W less on load and 5 celcius less in load.
As for the low voltage, most C2D/C2Q CPUs can handle very low voltages at stock voltages. And since the E8xxx series is the top-pick, they're probably the best candidates to near-1V operation (and even sub-1V, but I've never seen sub-1V available for desktop CPUs except through direct BIOS options, which are not the same thing...).
Just fixed my HTPC with one of these boards...
Slightly silly question here that isn't relative to just this board.
I'm building a new machine that would ideally serve as my main pc and a HTPC. I run dual monitors and my TV is only about 20 ft away from my computer, so seemingly I could keep one monitor hooked up to the DVI output, and the 2nd monitor hooked to an HDMI switch box that also runs to my TV. I only ever use my TV when I'm not using my PC.
This sounds like it would work great, or am I missing something painfully obvious?
Very nice, indeed!I once had a QX9650, it was stable @0,83V @2,33ghz that would be great on the zotac board
I've said it before in this thread, but I'll say it again: undervolting is not as easy as it sounds.But i fint Zotacs excuses stupid, when not having an option for undervolting when every MOBO producer on the globe has this option....
Also, you might want to check SPCR forums, there is a guy selling high-wattage, low-priced (and quite good, actually) DC/DC boards with power regulators and (if you want) high-efficiency AC/DC bricks.
Cheers.
Miguel
inolen, while I've not tried hooking up the DVI and HDMI port on mine, I am running dual monitor from mine. I've got a small 7"LCD touch panel in my HTPC case which I plug into the dsub port. The TV gets plugged into the HDMI port.
I'll test it out plugging a second monitor into the DVI port (instead of the dsub) and get back to you.
Cheers,
Dave.
