ZOTAC A75-ITX WiFi
Pjalchemist
http://www.zotac.com/index.php?page...0&option=com_virtuemart&Itemid=100270&lang=en
Maximize CPU and GPU synergy with the AMD APU-compatible ZOTAC A75-ITX WiFi mini-ITX platform for a revolutionary system that combines multi-core processing with up to 400 AMD Radeon™ cores. The ZOTAC A75-ITX WiFi packs an AMD FM1 socket ready to accept AMD APUs with discrete-class AMD Radeon™ HD 6000 series graphics processors for outstanding Microsoft® DirectX® 11 visuals and world-class high-definition Blu-ray and streaming Internet video playback.
The AMD FM1 socket is accompanied by class-leading expansion capabilities with the ZOTAC A75-ITX WiFi including a PCI Express x16 slot, 4 SATA 6.0 Gb/s ports with RAID 0, 1, 0+1 support and up to eight USB 3.0 ports. The ZOTAC A75-ITX WiFi also packs superior networking capabilities including dual Gigabit Ethernet, 802.11n WiFi and Bluetooth 3.0 for connectivity with your wired and wireless network, and wireless devices and peripherals
Product Name
Product Name ZOTAC A75-ITX WiFi
Model
Model A75ITX-A-E
Chipset
Manufacturer AMD
Chipset A75
GPU AMD Radeon™ HD 6000 series ready
CPU Compatibility
Name AMD A8
AMD A6
AMD A4
E2 Series
Socket FM1
Bus NA
Memory
Memory Type DDR3
Memory Speed Up to 1866 MHz (varies by APU)
Slots 2 x 240-pin DIMM
Capacity Up to 8GB
CPU and Memory Compatibility List
CPU and Memory Compatibility List see above
3D API
DirectX DirectX 11
OpenGL OpenGL 3.2
Expansion
Slots 1 x PCI Express x16
Networking
Ethernet 2 x 10/100/1000Mbps
WiFi 802.11n & Bluetooth 3.0
Audio
Analog 8-ch HD
Digital Optical S/PDIF & HDMI outputs
Ports
DVI 1 (HDCP)
HDMI 1
VGA 1 (with included adapter)
SATA 4 (SATA 6.0 Gb/s)
eSATA N/A
PATA N/A
PS/2 1 (keyboard/mouse)
Serial Serial port header
USB Ports 8 x USB 3.0 (6 on back panel
2 via pin header)
2 x USB 2.0 (via pin header)
Cooler
Cooler Passive (no fan)
Form Factor
Form Factor mini-ITX
OS Compatibility
Windows Certified for Windows® 7
General
SLI Supported no
Maximum Resolution 2048x1536
Other
Wake-On Support Wake-on USB
Wake-on-LAN
Overclocking features N/A
Packaging
Package Contents ZOTAC A75-ITX WiFi motherboard
3 x SATA cables
1 x DVI-to-VGA adapter
2 x WiFi antennas
1 x I/O back plate
Graphics Output 1 DVI / 1 HDMI / 1 VGA
I personly think this is better than the ASUS or any other A75 ITX offering!!
