Hi,
I just got my ZOTAC GeForce 9300-ITX WiFi (PCB 04, the newest version), and my problem is that I can't get SpeedFan (and other hardware monitoring apps) working.
I updated the BIOS to the latest version (this one: http://www.zotac.com/index.php?option=com_docman&task=doc_details&gid=397&Itemid=100032&lang=nd).
And installed the latest Nvidia chipset drivers.
When running SpeedFan, the following is detected:
Win9x:NO 64Bit:YES GiveIO:NO SpeedFan:YES
I/O properly initialized
Linked ISA BUS at $0290
Linked nVidia MCP79 SMBUS at $1C00
Linked nVidia MCP79 SMBUS at $1C80
No active display found! (## running this one from a terminal)
Scanning ISA BUS at $0290...
Scanning nForce2 SMBus at $1C00...
Scanning nForce2 SMBus at $1C80...
Found WDC WD5000BEVT-22A0RT0 on AdvSMART
Found Pentium(R) Dual-Core CPU E5400 @ 2.70GHz
End of detection
Loaded 0 events
I can see the temperature of HD0, Core 0, Core 1 and sometimes (!) it also finds the GPU. However, the temperatures of Core 0 and Core 1 is not reporting the same temperature as the BIOS (CPU temperature).
I would really like to get this working so I'm also able to adjust and monitor the fan speed.
Any ideas?
End of detection
Loaded 0 events
Any ideas?
