ZFS ZIL and L2ARC cache drive
Dr.Evil
Is is possible to use on SSD with multiple volumes on it for both the ZIL and L2ARC cache?
I was thinking about picking up one of the new sandforce 2000 drives and carving it up and using it for both caches since it has high read and write speeds plus decent random IOP specs.
Just don't know if you could do this with something like nexentaCore/Stor or another form of OpenSolaris.
You should not use SLOG/ZIL device, unless:
- the SSD can write safely using a supercapacitor; not sure if SF-2000 has this; Intel G3 will have it
- you are running pool version 19 or are mirroring the SLOG; otherwise, losing the SLOG device can cause you to lose the whole pool; basically everything!
That is good to know as it would save money by being able to use one SSD for the ZIL and L2ARC and still get the benefits while not having to spend a tone of money.
Especially since you can grab that A-Data 64GB Sandforce for $111 just about everywhere that sells it.
IIRC NexentaStor/Core 3+ should be using pool version 26, correct?
Is there an easy way to find out from the system itself?
BTW what was changed after pool version 19 that fixed this?
yes and yes: "zpool get version <poolname>"
odditory: he was referring to the ZFS system version; not of the pool. I'm not sure how this works on OpenSolaris; on FreeBSD you get to see the ZFS versions on boot in white bold text, and in sysctl variable.
But an easy workaround is:
zpool upgrade -v
lists all versions up until the system version, same for filesystems:
zfs upgrade -v
nice catch - thanks for the command, i've been using NexentaCore only a few days so i'm still relatively clueless. next step is figuring out if there's a way to spindown the drives in a pool.
