Just wanted to start a thread to publish some performance numbers here with a new test setup that I have been playign with and get some input.
Config:
Q6600
P5Q-E
8GB RAM
AOC-USAS-L8i
HP Expander
750Watt PC&P
14x 1TB 7200.12's
OpenSolaris 2009.06 & latest SVN (134 i think)
These results are on 2009.06 with the 14 drives configured in different ways using dd for some simple write tests to compare speeds.
14 drive Raid10 - 316MB/s Write
7 drive Raidz2 - 318MB/s Write
14 drive Raid60 (two 7 disk Raidz2) - 376MB/s Write
13 Drive Stripe - 382MB/s Write
the 7 drive raidz2 writes look about right to me as it is close ot the same as the speeds i have seen on my other test box (330MB/s write to a 7 disk raidz2) though the scaling on the other tests (14 drive raid60, and the stripe) do not seem even remotly proper to me.
Based on 50MB/s write per disk the stripe should be pulling ~700MB/s
I must be hitting a bottleneck of a wall here somewere and would like to track it down.
Watching the box access LEDS during a long write is interesting as well... the data access/write is in little patches, drive access for 2-3 seconds, 1 second no acces, 2-3 seconds of access, etc. Now one of the drives is accessing wile the others are not wich is odd.... iostat doesent report any odd writes on that drive either... wich is kinda odd...
Curious if anyone can help shed some light on these puzzling numbers... I'm going to see if I can get filebench installed and do some testing with it.
Config:
Q6600
P5Q-E
8GB RAM
AOC-USAS-L8i
HP Expander
750Watt PC&P
14x 1TB 7200.12's
