coolrunnings
- Nov 21, 2004
A bit of background: I have an HP ML110 G7 server. For those unfamiliar with the series, they have 4 SATA/SAS hotswap bays. I currently have 4x 1tb WD Black Edition 7200rpm SATA 3G drives in it. I am getting an IBM M1015 card so I can run ESXi and do an all-in-one server. I plan to run 3-4 VMs at a time off of this as well as stream large data files (backup images) to it frequently. I am wondering about the best way to set up the pool for both expansion as well as performance. I currently have 3 drives set up in a RAIDZ and with this can almost saturate gigabit ethernet. On to my questions:
1. Can I set up the drives in pairs of mirrors, then add them all to one pool to combine them, I am thinking this would allow me to add another pair of 1tb drives in the future for a total of 6 drives. Would this give me the same level of redundancy as a RAIDZ3 pool but better speed or am I misunderstanding how this works? Basically I'm trying to get around the destroy/rebuild the pool problem when adding storage but I don't want to sacrifice redundancy or performance.
2. I have a second server - a Dell PowerEdge T110 (g1, not g2). Currently this has 3x 2tb Samsung F4 drives in it (yep, 4k drives). I am thinking of making this into a second all-in-one with a RAIDZ1 for the sole purpose of backing up large data files and backups of the first all-in-one server. Will the 4k cluster size cause me performance/reliability problems doing this? Would it be better to get another F4 drive and do 2 mirrors instead?
Thanks for the help guys! Oh, and _GEA - YOU ROCK!!! Thanks for all your hard work on Napp-IT. I'm in the process of testing this and will see if I can get you some commercial accounts that will donate to the project.
