Gamers Nexus saw 2% or less gains with their update. It's just that a couple reviewers like Anandtech were really pushed off the mark.
Did they retest power consumption and temps with the new BIOS?
Hardware Unboxed tested 36 games at 1080p with both CPUs (9900k and 3900X) stock, and both overclocked. Used 2080 Ti for GPU.
His results were a 6% average gap across all games when both CPUs were stock, and a 5% average gap when both CPUs were overclocked (9900k @ 5GHz, and 3900X with PBO + Auto OC).
PBO is an automatic overclocking solution.
Temps were unchanged. I didn't check power consumption, but I have no reason to think it changed. I've never seen drastically different power consumption over a BIOS upgrade.
GN went into detail about the differences between "PBO" and "Auto OC" settings in this video. PBO doesn't explicitly enable the +200 MHz max boost clock that "Auto OC" does. Supposedly. So in Ryzen 3k they are two different settings that both enable some level of overclocking. The maximum available is if both are turned on.
Again, supposedly. I don't have a 3900X in my hands (yet) to test myself. The results are not exactly earth-shattering though.
The Stilt measured 27W and 7°C deltas with a change of BIOS on his Asus board because a version was flawed.
So close so close! Can't wait for Intel's response and AMD's next update.
I love that this launch there is not much of "Wait for apps/games updates to increase Ryzen performance" it's just so good out of the gate.
There's literally nothing bad I can say about this launch except Intel has an edge in high fps gaming and Ryzen could use a little more headroom to overclock/tinker with.
I think we are seeing the end of over clocking as we know it now. Even from Intel, and they know it. That's why they are milking as much as they can from 14mm.
Ryzen has overclocked like ass over three revisions and two nodes. For their desktop parts, AMD is running them to the edge of their design.
Intel has gotten significant use out of 32nm, 22nm, and now 14nm- and while they've quite publicly stumbled with 10nm, the jury is still out on the potential of dedicated 10nm desktop parts.
But it looks like AMD is going to have to revise Zen to actually hit higher clockspeeds if that's a game that they want to compete in going forward.
I had hoped they might change that practice this time around, but it seems to be basic company philosophy at this point, so I doubt it will change next time around.
The days 'shrink the node and get automagical clockspeed increases' are over. I suspect - don't know - that 10nm doesn't scale well with clockspeed (yet?), and that's why we continue to see Skylake refreshes.
Perhaps. The TSMC 7nm process is new. AMD has had a pretty consistent 'add a couple hundred MHz' trend each generation. I bet AMD and TSMC wring a little more out of 7nm over time. Not a lot. But a little. AMD may yet eek out 5GHz boost next go around. Or not. Who knows?
But ~5GHz appears to be the wall for just about everything. I remember golden sample Sandy Bridge overclocks hitting 5GHz (and 4.5 being pretty achievable for most samples, tweaked right). Things haven't changed all that much in terms of max clockspeeds since then.
I don't think you quite get it:. Intel is facing clock reductions with die shrink. Which means they will also have to run their new processors not based off 14mm near the edge as well to compete. As I said, overclocking as we know it is coming to an end.
I don't think you get it: Intel has only produced mobile parts on 10nm. We have no idea what the desktop parts that would compete with Zen 2 on the desktop will do.
And those mobile Intel parts wipe the floor with Zen.
Looks like they lost 100Mhz of boost from the 8650U 14nm to the leaked 1065G7. For being 12nm Zen+ cores, the mobile AMD parts look fairly decent for what they are.
Yet gained performance at those speeds- which means that they increased battery life, which for ultrabooks, matters more than outright performance. Should also decrease thermal load and thus noise, also important.
Where AMD stands is, quite literally, not available. No competitive part whatsoever.
And I say that as someone that wishes that they did.
Competitiveness isn't solely based on performance, cost also plays a factor, as well as availability. When will the latest intel parts actually be available for purchase? Wife needs a new ultrathin laptop
There's no price cut for the new stuff. The new amd stuff will have no direct competition coming from Intel for quite a while. The Intel stuff games a bit better, but most pure gamers in this world have a cell phone and/or a consoleAMD launch - Intel response- amd price cut is always good.
Hopefully the pattern holds.
That's irrelevant to consumers because you can't market that. End of story Intel regressed on 10nm in overall performance hence it's nowhere yet.Yet gained performance at those speeds- which means that they increased battery life, which for ultrabooks, matters more than outright performance. Should also decrease thermal load and thus noise, also important.
HAHA, why is your response about mobile processors, when we are talking about desktop processors? Their 10mm parts are so good, that we will be seeing desktop processors when???
Oh wait.. not going to happen, they are skipping it and going straight to 7nm. As I said, you don't get it.
When Intel finally releases a desktop processor on 7nm, it will be lower clocks with more cores, compared to what they offer now, with little head room for overclocking, just as Ryzen. That's my call.. we will just have to wait till 2021 to find out.
Cannonlake used 10 and Icelake uses 10+. Higher clockspeed would be achieved by 10++
AMD has been loosing MHz pretty consistently before partially recovering.
Fastest 4C
It is the frequency wall. We reach the limits of silicon, time ago.
You can't market longer battery life in a mobile device...?
Quite the opposite- the story hasn't yet started.
Source? I understand if you don't have one.
I won't bet on Intel performing as poorly as AMD.
I understand you are oblivious to reality and need people to source information that has been top news for a few months now, that you chose to ignore:
https://www.theinquirer.net/inquirer/news/3074879/intel-roadmap-leak-desktop-core-14nm-two-years
https://www.extremetech.com/computi...unch-7nm-chips-in-2021-ice-lake-ships-in-june
https://www.google.com/amp/s/www.te...tel-roadmap-shows-10nm-desktop-cpus-wont.html
https://www.google.com/amp/s/wccfte...14nm-comet-lake-10nm-ice-lake-tiger-lake/amp/
The last link talks about 2022 for 10nm LGA parts... Which implies its even worse...
There are many more articles out there... But Intel's own road map tells all.
Not sure how much I trust all the 'leaked' stuff. But in any event doesn't tell us much we don't already know. We'll get at least one more refresh of Skylake on 14nm (number of pluses TBD). After that, we'll probably get 10nm desktop parts. At what clockspeed... who knows?
Probably true. How much higher is anybody's guess. My suspicion is still probably lower than 14++.
Provided values don't really work for this argument. Bulldozer and derived designs were designed for higher initial clockspeeds than Zen. Steamroller and Excavator did not have 'enthusiast' FX branded parts, and were thus not directly comparable to Piledriver in this respect.
This is disingenuous, juanrga. Up until now in this thread the metric being used for max clocks has been max boost clock (1C-2C). You change the metric being used to improve the perception of your position. Bad form, sir. You know better!
Max Boost, 1C-2C. Zen.
Zen: 4.1 (XFR), 4.2 (TR)
Zen+: 4.35, 4.4 (TR)
Zen 2: 4.6 (July), 4.7 (Sept). TR: ???
Zen 3: ??? 4.9-5GHz maybe?
Steamroller and Excavator FX branded parts were cancelled because the nodes used couldn't hit same clocks than the 32SOI node used by Piledriver. That is why clocks reduced, as I showed.
I have given base clocks and max 1C clocks. E.g. the "3.6/4.0GHz" I quoted for Zen+ is the base clock and max boost of the R5-2500X.
I am quoting the max clock achieved for equivalent SKUs. You are quoting the max clocks of each gen independently of the SKU. You are mixing node improvements with high binding for some premium products. If I was to include special binding, then I had quoted the clocks of the special binned 8C FX-9590, instead the "4.2/4.3GHz" I quoted for mainstream 4C Piledriver.
2500X isn't an 'equivalent SKU' to much of anything.
I was typing something else, but I had to look up what these things are. They look like single-CCX Zen+ dies (I thought they were just graphics-less APUs at first), which at least looks somewhat attractive compared to the lowest-end Intel parts.
Still, lack of retail availability does make any detailed comparison pretty moot.
