zalman7000-7700
demons9872
would i see a difference if i went from the zalman 7000 with the 92mm fan to the 7700 with the120 mm fan if so how much
What fan speeds do you plan on running at? What kind of thermal paste do you use? What version of those coolers are you talking about, AlCu or Cu?
You might see a difference but as to whether that difference will turn into any increased overclock, I doubt it.
im using the cnps 7000b-cu led was thinking about getting the bigger one would i see a difference im using the zalman thermal grease
