Zalman 9700 - NT vs LED??
defiant007
So which is better?? The plain copper version or the copper-aluminium hybrid?
Am going to be buying one of these within the next couple of hours so quick responses would be appreciated! :cool:
i think both are the same, ones meant for hte amd and the ohter for intel, or they are just different colors... just my opninon tho...
I have a 9500 led, the copper colored version with the blue lights. It is amazing!! the 9700 is the upgraded version. I recently purchased a 9500 AM2 for my new FX 60. I am a little tired of the blue LEDs so I decided to switch on over to green. My old 9500 LED will be donated to my GF's new rig; my old one. (4800 + 7900 GT 512)
I did some online research for you and found some reviews.
The have a bunch listed on their website
http://www.zalman.co.kr/eng/pr/review_list.asp?page=1&sKey=&search=
These are the Specifications that I found
9500 LED 53.99 @ newegg
92 mm Fan
noise 16.2-30.25 dba
85mm Long X 112mm wide X 125mm High
9500 AM2 (AMD sockets Only!!) 48.99 @ newegg
Same specs as above
9700 LED 59.99 @ newEgg
noise 19.5 - 35 dba
90mm long 124 mm wide 142mm high
9700 (Green LED's) 69.99 @ newegg
Same as above
Anyways:
9700 NT, (green LED) The "NT" stands for nVidia Themed, I think. This is why it is green.
Test platform:
Asus P5WDH deluxe
Core 2 Duo 6400 @ 3.2 GHz
Socket 775
PC Power & Cooling Silence 750
WD Raptor 74
Plextor 755 SA
Ballistic Tracer DDR2 PC2 6400
Idle Temp 35 degrees C
Load Temp 52 Degrees C
9700 LED (copper Blue Lights) ( Tested @ room Temp of 80-81 Degrees F )
P5NE Sli
e 6300 1.86- 3.06 GHz
OCZ PC2 9200
8800GTX
Seagate 7200.9 320 Gig
1.86
41 idle
56 Load
3.06 Low fan speed
43 idle
56 Load
3.06 high Fan speed
42 idle
52 Load
9500 LED
P4 520 prescott 775 2.8
Radeon X300 128
WD 76 Gig
corsair XMS 512 X 2
idle 34 Degrees C
load 42 Degrees C
9500 LED
AMD 64 3200 S939
DFi Lanparty UT NF4 Ultra
OCZ 3700 1 Gig
Sapphire X 300
Maxtor 80 Gig
High Fan
Idle 26 Degrees C
Load 31 Degrees C
silent
Idle 30 degrees C
Load35 Degrees C
Processor OC to 3400 +
High Fan
idle 35 Degrees C
Load 40 Degrees C
Silent
Idle 38 Degrees C
Load 41 Degrees C
Hope this helps your decision making.
Much appreciated and A+ for effort.....but that doesnt really help me in terms of indicating what the performance difference is between the LED and NT version given that they were tested on completely different platforms.
Surely someone would have tested both versions?
jeez there is no fraking difference (which is probally why a comparison review is not to be found.) except :
CNPS9700 NT
Automatic Fan Speed Control feature included in the Ultra Quiet 110mm PWM(Pulse Width Modulation) enabled fan.
CNPS9700 LED
Ultra quiet CNPS 110mm LED fan.
Adjustable fan speed controller (FAN MATE 2) included.
and the pretty lights/color. woot! woot! and all that shitz.
So if you are going to disable the motherboards automatic fan speed control EIST, cool and quiet whatever on the MB for overclocking you probally want the LED model, if you want the MB to control the fan get the NT.
I dont care for either of them for cooling performance, but I WC. :p
Not to say this review is the last word, its your machine and you get what you like, but...
http://www.anandtech.com/casecooling/showdoc.aspx?i=2943&p=3
Screw in heatsink and fan! I'm sold on this diddy.. Gonna order it now.. Great info guys..
