You Should Care about the Supreme Court Case on Toner Cartridges
Discussion in 'HardForum Tech News' started by Megalith, Mar 25, 2017.
  1. viscountalpha
    viscountalpha 2[H]4U
    2,545
    Oct 16, 2011
    While a legitimate issue that could have been solved with "non specific parts void warranty"
  2. Master_shake_
    Master_shake_ [H]ardForum Junkie
    9,679
    Apr 9, 2012
    let's cut them off at the pass.
    ban paper.
    that way we will never be subject to printer cartels and their expensive as balls inks and toners.
    Wrecked Em likes this.
  3. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    they work great in my printer. and 20 bucks in ink got me a whole box of cartridges, 24 i think it was, instead of one.
  4. rudy
    rudy [H]ardForum Junkie
    8,586
    Apr 4, 2004
    Why is knock off ink damaging printers? That is the question I have. Imagine if you design a car and for whatever reason if you do not use a specific brand of tire your car has some failure that requires service. Also how does one know if the damage to the printer was not a purposeful engineering feat to force people to use first party cartridges? I view this case very similar to cars, a car maker cannot void your entire car warranty if you put any aftermarket part in unless they can show that part caused the damage. This is how printers and really ANY device should be treated legally.
    For me personally I find printers to be really a pain, they break down a lot, ink is expensive and my solution has been to just try to not use them at all. I read online, I try to fill out and turn in documents through email, I use MS onenote to take notes and my phone to keep them on me. All in all I find my life a lot easier not just because of not needing printers but because there is simply far less paper filling up my lifes file cabinets, desks and every place in the house. 1 computer and a cloud server can store millions of pieces of paper worth of information, make it accessible from anywhere, easy to duplicate if I want to send it to someone, etc...
    viscountalpha likes this.
  5. nilepez
    nilepez [H]ardForum Junkie
    11,483
    Jan 21, 2005
    The cheaper printers are sold at a huge loss and the loss is made up by selling ink cartridges (or toner cartridges). For ink jet, the cheaper the printer the more the ink costs (IME). I have to believe that this suit was brought, because they were starting to see it cut into profits on those printers. If Lexmark works like Epson, the cheap printers are sold for less than the price of ink on the cheapest printers and the cheapest printers get less ink/$ than more expensive printers.
    It's the business model. If that goes away, $50.00 printers have to go away too.
  6. Exavior
    Exavior [H]ardForum Junkie
    9,660
    Dec 13, 2005
    why or how? There is a slight difference there. Does it always damage the printer no. Can it damage it? Under some cases yes. Mostly because there is no standard for quality then. Using the oil analog many have brought up, let's say that I start selling something as full synthetic oil, but really it is used oil that I have thinned out with water and put into new drums. Do you agree that will damage your car? What if I started selling something as 5w-30 that was not at standards for that? When it comes to toner the issues that I have seen is that the cartridge is poorly designed and ends up leaking toner into the printer and in some cases ends up getting into all the rollers which then bakes onto the transfer roller. In some cases taking a printer apart and blowing it out was enough. Others needed all new rollers, one needed a new fuser as that got full of so much toner. That is what I have seen personally, which mileage may vary.
  7. dj_spanmaster
    dj_spanmaster Limp Gawd
    413
    Aug 1, 2004
    Thank god Gorsuch isn't on there yet. Dude would undoubtedly side with Lexmark automatically.
    nightfly likes this.
  8. Dr. Righteous
    Dr. Righteous 2[H]4U
    3,147
    Aug 1, 2007
    I'm not against anyone using non-OEM toners; but my advise is always "you get what you pay for".
    If you want the best quality and reliability by the OEM. The issue is that OEM toners are built to very strict quality standards. There are NO standards for knock off toners.
    Believe me, some brands are guys building them in their garage.
  9. Jagger100
    Jagger100 [H]ardness Supreme
    7,499
    Oct 31, 2004
    The solution is to void the warranty.
    For the money I can save with 3rd party cartridges, voiding the warranty is a price I'll gladly pay.
    The proposed solution is much more broad than what is necessary for that issue. It's to create a captive market.
    The long term problem for them is if they succeed, they will create a market for knock off Chinese printers. Not conterfeits, but close copies. They'll suck at first but will eventually get it together. I guess they want to commit corporate suicide.
  10. Jagger100
    7,499
    Oct 31, 2004
    Which is cheaper
    $50 printer + $70 cartridge + $70 cartridge, or
    $100 printer + $20 cartridge + $20 cartridge.
    ($190 vs. $140) with a $50 dollar advantage with each additional cartridge.
    The printer is subsidized to lock you in to their overpriced cartridges. It's not an act of kindness.
  11. kledar586
    kledar586 [H]ard|Gawd
    1,063
    Aug 8, 2009
    The quality concern is the reason why I don't buy the third party toners, I know they are a lot cheaper but if they do damage my printer, even tho the printer relatively cheap, it creates additional work for me and causes quite a bit of inconvenience.
  12. Dr. Righteous
    3,147
    Aug 1, 2007
    In every case besides the printer being broken to begin with or the customer using knock off ink; the main reason the wax-ink Xerox failed to preform was they sit idle all the time and are only used occasionally.
    All liquid ink printers preform best when they are used regularly. In the case of the Xerox sitting idle all the time is the worst thing for it. It has to constantly purge the ink because if left too long in a melted state it starts to go bad. The yellow will turn brown when you print.
    I serviced some Xerox Phasers for a guy that run a small business out of his garage. He actually had a cool idea. He reproduced factory operators manuals for old equipment. Like a op manual for a Apple IIe. He said you would be surprised at the demand. He printed and bound them identical to the original ones. He had 2 Xerox printer that produces the print and graphics and he ran them hard all the time and they preformed great. He liked them because the color graphics prints resembled the original graphics done on a 4 color press. A laser printer couldn't reproduce the same color vibrancy on plain paper.
  13. nilepez
    11,483
    Jan 21, 2005
    I understand that, but that hasn't stopped people from buying the cheapest printers.
    That said, for Laser, I really don't care. I've been on the original toner cartridge for several years (5-8 years). I did have to put tape over the holes that it uses to say it's empty last year (because it's not really empty), but even if it was, that's way better than inkjets, which clog if you don't use them regularly.
  14. modi123
    modi123 [H]ardness Supreme
    5,500
    Sep 6, 2006
    A win today.
    Citation
    GoldenTiger, Armenius, rhouck and 3 others like this.
  15. DukenukemX
    DukenukemX [H]ardness Supreme
    4,451
    Jan 30, 2005
    I didn't need anyone's permission to refill my ink cartridge. I got sick and tired of buying overpriced ink and did one better. I now bought special cartridges that are meant to be refilled and the ink I buy is like $20 that I can refill for at least 1 years use.
  16. nilepez
    11,483
    Jan 21, 2005
    This is great news. I don't use Ink Jets anymore (laser is cheaper and online print shops do a great job printing photos at a low price).
  17. Dead Parrot
    Dead Parrot 2[H]4U
    2,551
    Mar 4, 2013
    Surprising but great news. Wonder how this will affect the John Deere Co.'s efforts to lock farmers into John Deere approved parts and software modifications?
    As others have commented, for most folks inkjets are a value trap. Owned one Epson color inkjet years ago. Might have got 50 printed sheets out of 3 sets of cartridges because I didn't print very often. Replaced with a HP Laserjet 1200, which is still in use today. Am on the 3rd or 4th toner.
    frelled, drescherjm and Nukester like this.
  18. James Robinson
    James Robinson Limp Gawd
    292
    Dec 4, 2016
    HP does the same thing... they use that little chip to retard operation after an amount of time, even if the cartridge is still full.
    Gasaraki_ likes this.
  19. Spidey329
    Spidey329 [H]ardForum Junkie
    8,676
    Dec 15, 2003
    More DRM.
    Sure, you don't have to buy parts/consumables from us, but ours are the only ones with the decryption key, so good luck getting our OS to recognize the new part and not run in limp-dick mode.
    I think that will be part of a Terms of Service / DCMA challenge. Can software licensing (the OS the tractor runs, in this example) disable a rightfully purchased vehicle after the first sale? You see this in a lot of vehicles, such as BMW/etc - if an official part isn't used and reset by the manufacturer in the OS, the vehicle will limit some functionality / operate in a reduced mode. Attempts to allow consumer software tools to adjust these settings are met with DCMA lawsuits.
  20. vegeta535
    vegeta535 2[H]4U
    3,313
    Jul 19, 2013
    I used to just buy a new printer back in the day when ink ran out lol. Worked out to be cheaper if not a few dollars more to replace the cartridge. I just use my work printer if I need to print anything nowadays.
  21. ccmfreak2
    ccmfreak2 Limp Gawd
    318
    Jul 27, 2009
    In China, aftermarket toner cartridges were everywhere and dirt cheap - it was paper that everyone considered to be expensive in a large print job. (But that had more to do with the laws that prevented the cutting of trees as they tried to push back the spread of the desert.) The fact that this company can now take lexmark cartridges and sell them back to consumers at discounted prices will really help bring more affordability to the toner marketspace, and really challenge the corporatism that controls and plagues the market.
    Then there's the ramifications this ruling could have on John Deer and other manufacturers that try to control their goods after they've been sold....
    Long Live The Free Market!
  22. ccmfreak2
    ccmfreak2 Limp Gawd
    318
    Jul 27, 2009
    That's the beauty of this lawsuit. This company uses Lexmark products, so they don't need to decrypt anything. It already is a "genuine" product. Lexmark already has tech in place that prevents after-market cartridges from being recognized. But these are actual Lexmark cartridges that are being bought from consumers and reused. The biggest concern this company might have is if they have to change any code in the toner firmware to get it to recognize itself as now being "full." If they do, then there's a potential lawsuit angle that Lexmark could leverage against them in a counter-suit.
  23. nutzo
    nutzo [H]ardness Supreme
    7,380
    Feb 15, 2004
    When I get a new printer for the office, I buy an OEM toner the 1st time since the printer is still under warranty. After that it's always 3rd party.
    I have HP printers with over 300,000 pages on generic toner.
    At home I also use generic toner & ink. Inkjet printers only seem to last 2-3 years even with OEM ink. You just need to find a reliable company to buy better generic toner/ink istead of just buying the cheapest stuff you can find.
  24. Mike89
    Mike89 Gawd
    702
    Jan 27, 2003
    Good decision for the consumer. The problem remains how to make remanufactured third party ink cartridges to work right. In all my years of using inkjet printers, I have never found a third party ink cartridge that worked worth a crap. Spend about half as much money but end up throwing them away because of all the hassle associated with them. Don't know what formulations are used by the big boys but so far have not even been close to duplicated.
  25. wizzi01
    wizzi01 2[H]4U
    2,323
    Apr 25, 2008
    Consumers should be able to use whatever cartridge they want. If that cartridge is the reason the printer broke the manufacturer should be able to refuse the warranty. There is a reason the USA has the Magnuson Moss Act.
  26. nilepez
    11,483
    Jan 21, 2005
    Mostly agree, but I suspect this will change the model of cheap entry level printers. Whether it's laser toner carts or ink jet carts, the reality is that most of the entry level models are sold at a loss and they expect to make it back from ink/toner sales (much like razor companies make their money on blade replacements
  27. MrGreg62
    MrGreg62 Lurker
    1,095
    May 2, 2003
    AFAIK this will not affect much price wise when the markets settle. The main sticking point in this lawsuit was not the sale of pre-used consumer cartridges per se but the resale of cartridges that originate from foreign countries where they are sold for less money with the disclaimer that they were not for resale in NA. Eventually the price is going to even out because Lexmark (in this case) will start charging more money for these cartridges in these foreign countries.
  28. TechLarry
    TechLarry Can't find the G Spot
    30,165
    Aug 9, 2005
    It doesn't matter. They will still figure out a way to cut us with the Razor Blade.
  29. GlowingGhoul
    GlowingGhoul Whines about Whiners
    445
    Jun 13, 2013
    Yeah, well, looks like your Socialist Goddess had to throw a bone to her globalist masters. Hopefully nature takes it's course and RBG gets her just reward in a nice, comfy nursing home real soon.
    All the liberals here seem to forget Hollywood is closely aligned with the Dems, as well as the globalist billionaire class like George Soros, Zuckerberg, and Bezos (who are doing all they can to force you to compete with the cheapest labor on the planet....for your benefit I'm sure). It was the Republicans that stopped the horrific Stop Online Piracy Act, that would have had even further reaching impacts than this.
    What does Crow taste like?
    GoldenTiger likes this.
  30. VRT
    VRT Limp Gawd
    460
    Jul 15, 2016
    Tell you what I hope that there is more of this to come, especially from the right to repair stance. Look at what John Deer has done with their tractors etc. I have family and friends that are farmers and it is BS! A lot of people think that this is a not me problem, but it is!
    GlowingGhoul likes this.
  31. sir-gold
    sir-gold Gawd
    931
    Jan 19, 2006
    I don't know if it applies here, but some printer companies were adding an automatic expiration for cartridges, where the cartridge would record the date when it was first installed, and report empty after a set amount of time had passed, regardless of actual ink level remaining.
  32. midnightfrolic
    midnightfrolic [H]Lite
    79
    Dec 20, 2015
    If not done so already, printer manufacturers will be more aggressive about checking for genuine branded ink tanks and it's expiration date. It will give them a good reason to refuse warranty because 3rd party ink tanks were used.
    Manufacturer branded ink tanks already report expiration date, whether they were new, sealed, or not, they 'expire'. Those who purchased them well in advance were out of luck. That's a lawsuit on it's own.
    If you can game the system, why not. But if the ink tanks, or whatever part you got for your gadget, caused unit to fail, then it's on you and the 3rd party. I'm sure there is a disclaimer that states they are not responsible if products damages devices. Like rechargeable batteries that explodes and destroys your brand new $1000 gadget.
  33. nilepez
    11,483
    Jan 21, 2005
    The Koch Bros, Adelson, Mercer, Thiel, and Langone, to name but 5 billionaire GOP supporters (6 if you count both Koch Bros) with interests around the world
  34. zkostik
    zkostik Gawd
    929
    Sep 17, 2009
    Problem is that most consumers simply don't know and go for cheapest printer as it looks like a better deal or listen to sales reps who push higher margin stuff as these customers will later come for ink. I'm sure a few get inkjet for its smaller size but I highly doubt that's the real issue. I have two Brother laser printers and had them for many years (like 8-9). Both work and oldest is on its second toner. They don't dry out, no heads to clean, really works best for those random print jobs. However very few people listen to any reason when I explain them the deal and still end up getting an inkjet. Oh well, it's their money. I just feel bad about that stuff as it creates so much waste (I'll save my sentiment for this whole consumerism society crap where everything is short lived and disposable).
  35. dj_spanmaster
    413
    Aug 1, 2004
    Wow, GlowingGhoul. Assuming I'm a socialist, drawing false comparisons, AND getting facts wrong! In order:
    - I said nothing about my own alignment, but we can discuss it if you ask nicely.
    - What do Hollywood, liberals, and socialism have to do with my Gorsuch/Lexmark comment?
    - I was relying on common knowledge of Gorsuch's pro-business tendencies though, so if you'd like citation I can provide it.
    - I suggest you brush up on SOPA history (https://en.wikipedia.org/wiki/Stop_Online_Piracy_Act). Republicans sponsored and championed the bill.
    - What does the fox say?
  36. sir-gold
    sir-gold Gawd
    931
    Jan 19, 2006
    It really depends on which part of Hollywood you are talking about.
    Directors, writers, actors, and production crew, sure I could see that. After all, it's hard to create something that appeals to the masses if you only think about yourself.
    Movie studio executives and financial backers (the kind of people most concerned with copyright and patent law) are solidly Republican though, because they are only in Hollywood to get rich, and the Republican party is the party of the rich.
