Primarily gaming, however a little bit of everything else as well.
Total? Probably around $1200, however I would like to spend as little as realistically possible. Around $600 would make me feel good about it.
3) Where do you live?
Ohio, unfortunately.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything besides the case and sound card. I'm mostly looking for core components right now though, accessories can come later.
Soundblaster X-Fi XtremeMusic. That's pretty much it.
6) Will you be overclocking?
Yes, however not immediately. I will overclock after I see the current performance and how much I need to squeeze out of it.
I have an LG L226WT 22" widescreen LCD. 1680x1050 native.
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing special
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Will be upgrading to Windows 7 64bit
Anyway, yes, it's another one of these threads. However, I've already done most of the homework myself, and I'm simply in need of some critique before I take the plunge. What I'm really looking for is the absolute best performance I can get, while spending as little possible on it.
Here's the situation: My computer is horribly out of date. It's still running an AMD Athlon XP 2600+, 2GB of mismatched memory, and an XFX 6800XT, which isn't even PCI-E. It's AGP.
So obviously everything has to go. Right now I'm just focusing on the core parts to get something up and running. Later on I can add the other accessories as I go. Here's what I've got going so far:
CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
Mobo: ASUS M4A79XTD EVO AM3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
PSU: CORSAIR CMPSU-650TX 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Hard Drive: SAMSUNG Spinpoint F3 HD103SJ 1TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Optical: ASUS Black 24X DVD+R
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
So far, before the combo deals and rebates it's up to just shy of $600. I did not list a GPU because I have access to a used GeForce 8800 GTS, assuming it still works properly. If it does work properly I was considering using it for a little while to keep the costs down and to see what will be coming out in the near future. If it doesn't work however, I'm most likely looking at a new Radeon HD 5770.
I would appreciate any opinions people have on this setup, especially seeing as how not upgrading for so long makes this a huge deal to me. Every time I had the money for it, something in life happened. Oh well, I got more than I expected on my tax return this year so I'm finally doing it.
Also, assuming that the 8800 GTS functions properly, I would like to hear feedback on whether or not you believe it would badly bottleneck the CPU, and if so would it be so much that a GPU upgrade is worth it right now regardless? Or should I try to go with the 8800 GTS to try to save a bit on the final cost until the new GPUs come out?
Thanks in advance.
