0810 said:cnet said running high refresh rates on LCDs arent good for the monitor, so i run at 60
Scali said:You guys miss an important factor in the equation.
There is a phosphor coating inside the tube, which is what you see glowing after it has been hit by the electron ray.
There are various types of coating. On a TV for example (old ones, without digital scan etc), a relatively slow coating is used, because the tube will only be used at 50 or 60 hz.
The same with old monitors. The flickering is not that obvious, but there are slight ghosting problems because of the slow glow.
On a monitor that needs to work at 120 Hz or more, a much faster coating has to be used. The advantage is that the ghosting problem is much smaller. The disadvantage is that the glow is too short to run at low refreshrates, because the flicker is so much more apparent now that the pixels glow for much shorter periods of time.
I still have some old VGA monitors around that won't go over 60 or 70 Hz. But they never gave me a headache, they have perfectly still images (just think about it, if 60 or 70 Hz really was that bad, then in the old days everyone had constant headaches? They didn't).
However, I also have a high-end 17" monitor, that goes up to 120 Hz, and that one is horrible in 60 or 70 Hz.
I hope the clueless myth will finally come to a halt.
Terra said:I didn't know that any LCD's went further than "60Hz"?
Terra...
Makes perfect sense to me.Scali said:You guys miss an important factor in the equation.
Trepidati0n said:Ding, we have a winner. Sometimes having a high performance monitor isn't the best if you aren't going to run it at those refresh rates. However, it is VERY hard to get the engineer recommended refresh rate ouf a company. It took me about 3 hours on the phone with Viewsonic to find out my monitor is recommend for 85Hz to handle the phos they used properly.
-tReP
Komataguri said:The one thats giving me the flicker headache is an antique dell 15 inch.
It was made back in 96...I believe. So that would make it almost 10 years old.
0810 said:you can go to 75
burningrave101 said:You can select higher then 75Hz at lower resolutions if you uncheck the "hide modes this monitor does not support" and your using a monitor driver that will allow you to choose higher refresh rates.
Skrying said:What would be the advantage of running a LCD over 60Hz? The only thing with refresh rates I heard with LCD's is that 60Hz is what you want it at.
My brother runs his CRT at 75... I used to run the same one at 60. Let me tell ya it is death!!! Which is very strange becuase I have better than perfect vision... And no vision problems...Converge said:Most people who have never experienced refresh rates over 60 dont normally have a problem with it. Once you have a 75+ refresh rate monitor, if you try to go back to 60 you really notice the difference.
pr0nasaurus rex said:I do see a disturbing trend, though; it seems that many companies are discontinuing their high-end CRT monitors.
What a shame.
What a shame.
saturnine2 said:organic panels
http://www.audioholics.com/techtips/specsformats/organic_OLEDs_1.htmBigDaddy85 said:wat that? active matrix? plasma?
Excuse me? I'm old school, and for many years was at 640x480 when that was standard. I thought I was pushing the envelope when I moved to 800x600. And at 1024x768 I had to set the default font sizes larger to read stuff comfortably.Skrying said:I'd like to know how in the world you can hanle 1024x768, everything is so big and uncrisp looking, drives me crazy after getting used to 1280x1024 and higher.
burningrave101 said:I think its a good thing. With LCD production at a new high level prices will just continue to fall and LCD techonlogy is superior to CRT IMO. I can't stand using a CRT any more because they take up too much room and are harder on the eyes. They also consume more power. The response time is good enough on LCD's now that they are perfect for gaming as well as most everything else.
Besause some of us dont have the monitor right to the tip of our noseSkrying said:I'd like to know how in the world you can hanle 1024x768, everything is so big and uncrisp looking, drives me crazy after getting used to 1280x1024 and higher.
