yet another obstacle: 8800GTS upgrade
As some of you might've seen from this thread, I want to upgrade my pentium D processor to a c2d and my 7900 to a an 8800gts. Well after a few recommendations from you guys, I realized my power supply needed to be upgraded so as to handle the 8800.
Parts list:
vid card
processor
power supply
Everything was going well til I found out from dell that my mobo does not support c2d and that they only replace mobo; they don't recommend them.
So my question is what do I do at this point? What mobo should I be looking at. And since I'm to the point of having to replace my current mobo, I'd like the new mobo to give me room to grow. So should I go for the ASUS P5N-T Deluxe that's on the front page? Also, where do I go to make sure all these parts are compatible. I thank you for your time.
I am not sure if your mobo supports C2D, but I would give my pick for the Gigabyte DS3 on newegg for a sub-$100 motherboard, or you can go one step higher and get a rock solid Abit IP35 Pro on mwave for $130AR...
I also highly suggest you buy your parts somewhere else other then Dell...all on newegg... you can get the items for:
OCZ GameXstream 700W - $92AR
E6750 - $150ish
8800GTS - $180AR or go for the 8800GT for $140AR
I recommend ditching that OCZ GameXStream PSU. It's based off the FSP Episilon PSU design which has out of spec ripple, or voltage fluctuations, at high loads that can damage or kill your system. Granted, you may not reach such high loads but why pay for PSU that can kill your system?
This is a substantially better PSU for the price and wattage range:
Corsair 750TX 750W PSU - $101
Also you can get the 8800GTS 512MB for $100 cheaper here:
MSI NX8800GTS 8800GTS 512MB PCI-E Video Card - $210
And finally, I recommend getting the E8400 since you're getting a new mobo anyway. Speaking of new mobos, here's a few recommendations:
Gigabyte GA-EP35-DS3L Intel P35 Motherboard - $90
MSI P35 Neo2-FR Intel P35 Motherboard - $110
DFI BloodIron P35-T2RL Intel P35 Motherboard - $110
Gigabyte GA-EP35-DS3R Intel P35 Motherboard - $120
DFI LanParty DK P35-T2RS Intel P35 Motherboard - $130
Asus P5K-E Intel P35 Motherboard - $140
Gigabyte GA-EP35-DS3P Intel P35 Motherboard - $150
Asus P5K-E/Wifi-AP Intel P35 Motherboard - $150
Abit IP35 Pro Intel P35 Motherboard - $170
Gigabyte GA-EP35-DS4 Intel P35 Motherboard - $170
Gigabyte GA-EX38-DS4 Intel X38 Motherboard - $207
Just to help you out: If you don't need RAID, more than 4 SATA ports and only need semi-decent overclocking, check out the DS3L. If you need 5 SATA ports, 2 eSATA ports, slightly better overclocking, and a second PCI-E x16 port, then get the Neo2-Fr. If you want heavy overclocking options and six SATA ports, check out the Blood Iron. If you like the BloodIron but want significantly better overclock stability and options, go for the LanParty. If you want 8 SATA ports, RAID, legacy ports and high overclocks and optional eSATA, than the DS3R is a good choice. If you want the DS3R but need Firewire and a second PCI-E x16 port, then go for the DS3P. If you like the DS3P but need 3 PCI slots instead of the DS3P's 2 PCI slots and like having non-optional eSATA, go for the Asus P5K-E. If you like the P5K-E but need wifi, then go for the P5K-E/Wifi-AP. If you want something that can overclock pretty damn high along with RAID, eSATA ports and firewire connections, than the IP35 Pro. If you like the DS3P but want better cooling for overclocking, then go for the DS4. Do note that the Asus website can be slow sometimes.
Oh and if you had read the review for the ASUS P5N-T Deluxe, you would've found out that mobo is the kind of mobo you should avoid.
thanx for the detailed info guys, i'm checking out your links right now. I'm new to computer assembly so I won't be doing any over clocking anytime soon
Alright guys, i can't thank you enough for your help, here's what's in my cart
Intel Core 2 Duo E6750 2.66 GHz Dual-Core Processor
8800 GTS 512 MB PCI Express Graphics Card
Infinity BloodIron P35-T2RL LGA775 ATX Intel Processor Motherboard
Corsair 750 Watt TX Series Power Supply
I'm gonna order it all tonight but just wanted to run it by you guys once more. Danny I really wanted that E8400 you recommended but Dell doesn't carry it and that's who I have credit with at the moment
