Ok, so I picked up Vostro 400 for reeeeally cheap (800 with a 24inch LCD monitor)
Specs as it sits:
E6750 - 2.66ghz
4gb XMS2 DDR2 800
8800GT 512mb
160gb SATA
320gb SATA
20x DVD lightscribe burner
Vista Business --64 BIT--
when I installed the 4gb of ram first, I added it to the 1gb that I bought the computer with but it didnt see it all (3326mb i think is what vista shows)
I thought i read somewhere that the vostro only will take 4. so i pulled the last gig and there was no change.
So I did some reading, and evidently dell did not enable the memory mapping or something in the BIOS, and that if you pull one of the sticks, run a patch from intel, and put the other 2gb in it will work fine. Same thread i read that SP1 for vista does the same thing, except you don't have to pull the ram.
The chipset can support up to 8gb, bios shows 4096mb installed and 4095mb available, but Vista x64 only shows 3.25gb.
Thoughts?
Specs as it sits:
E6750 - 2.66ghz
4gb XMS2 DDR2 800
8800GT 512mb
160gb SATA
320gb SATA
Thoughts?
