Joe Average
Ad Blocker - Banned
- Apr 6, 2008
I can't tell the difference in performance between XP and Vista. Vista has more features, looks a lot nicer, and never crashes.
I'll stick with Vista.
I guess that's why its real world performance is pretty much identical to XP? If anything aero feels snappier and search is much faster.
You need to work on that comprehension. I didn't say the bloat caused lackluster performance, I just said Vista is bloated, and you can't honestly say that's not true. SuperFetch does balance out the performance equation over time but... XP takes up less than 1.3GB when installed fully (not counting Hibernation file requirements if enabled, the pagefile depending on RAM installed, nor System Restore points that are created during the installation - I'm talking about the bare metal space required to get the OS itself on the drive). Vista tops out at nearly 7GB for a basic installation.
So my point is Vista is bloated in extremes and it offers essentially the same basic OS functionality out of the box that XP does. Explorer for file management, Notepad for text files, Wordpad for simple word processing, etc - why is everything so much bigger and requires more space? And please, I'm making general statements because Vista takes more space than XP does (and XP Pro x64 also) after a clean installation - don't come back to the table of discussion with comparing the size of Explorer.exe and Notepad.exe in each OS; you're missing the point if you do. I'm talking about the entire OS as a whole.
That's where I'm speaking from in terms of bloat. It truly is amazing that considering Vista is ~6x larger when installed that it DOES still perform as well as it does, but with today's high powered "Godboxes" with dual, triple, and quad core powered CPUs, ridiculously high speed RAM and video cards, the differences don't really matter.
I'm not nor did I state Vista was slower, but it is after the installation - Vista gets faster over time but is slower than XP Pro x64 for the random period of time where it self-tunes on the hardware it's installed on, whereas XP starts off fast but gets slower over time. But XP Pro x64 isn't XP - it's Windows Server 2003 technically, and as such it doesn't suffer from the slowdowns that XP Pro x86 suffers. It's not the same codebase, it doesn't manage resources the same way, hence the fact that someone - including myself - is still interested in how XP Pro x64 compares to Vista x64.
As far as how it looks, that goes back to my function over form statements - I could care less about the GUI features in Vista, and I did state those were my personal desires and opinions, as yours are. If you like the way Vista looks over XP, fantastic, congrats - I'm just saying that means nothing to me whatsoever. And when I run Vista, I don't disable Aero, I just leave it alone and let it do its thing, not that I even notice.
Regarding crashes, I can really truly honestly say I have no idea what that means anymore. I have "quality" hardware - ok, let's just say it up front: I use Intel hardware, period, for the CPU and chipset - and I don't nor will I ever experience the small issues that many people do by choosing non-Intel based components. Some people out there get really lucky, far luckier than they realize, if they don't have issues with AMD CPUs, Nvidia or ATI chipsets (the old ones pre-AMD buyout), or some-higher-power forbid... VIA or SiS stuff. It's just how things go...
Some people throw the word "stable" around like it means something, and honestly the majority of folks out there don't know what it really means. Running Prime95 for 48 hours with some crazy overclock doesn't mean "stable" to me because most any PC can handle running a single program that just crunches numbers over and over for days, that's a piece of cake.
Now, if someone comes out with a benchmark that does 50 different things at the same time - applying Photoshop filters in random orders, creating/printing/calculating Word/Excel/PowerPoint documents, crunching video files, creating mp3 files, playing movies, music, etc and a whole lot more stuff at the same damned time including the number crunching and the overclocking too then I'd be impressed. But just running Prime95 with ORTHOS or something similar... that doesn't mean stable. It just means stable running that application, which is a snap. I've had machines that do 24 hours of ORTHOS crash in 5 minutes when running a combination of various programs at the same time, so much for stability.
I haven't seen a BSOD on this workstation of mine since I built it in the summer of 2007, and I've had probably 175 different OSes installed on it at one point or another, from Win95 through Win98SE (and yes, I mean installed on the bare hardware, not VMs although I use those as well), through 2K and XP, through Vista and 2K8, through Windows 7 build 6801, Linux distros galore (Arch Linux ftw!), and of course OSx86 over 50 times for testing new "hacks" of all sorts. Acronis True Image... a true lifesaver and timesaver if there ever was such a software product. Indispensable, without a shadow of a doubt.
So yeah, Vista gets the job done and is more compatible with more hardware out of the box (and after hitting Windows Update) than all previous versions of Windows, I'll be happy to agree with that. But it is more bloated to get basically the same job done, also, as most people should be happy to agree with, that much is a fact. As I said before, it's an amazing thing that considering its size it actually works as fast or faster than XP (meaning the 32 bit version), but in my own testing and experience, XP Pro x64 on this workstation has the edge, even after Vista has self-tuned, in day to day application performance, straight number crunching, and responsiveness.
Of course, I haven't spent the amount of time tweaking the hell out of Vista that I have with XP Pro x64 either... that could have something to do with it because I practice my own motto of leave it alone where Vista is concerned. But bring me an XP 32 bit or XP Pro x64 box and when you get it back you'll be amazed at just how fast it can really go...
Yes, I write long posts, sue me. And of course, I'm not your average Joe...
