MS says XP is tied to the hardware you originally install it to also. Why would we buy more expensive retail version of XP over OEM if this bit of backtracking double speak is true? Anyone here buy XP retail knowing the below to be fact?
http://www.winsupersite.com/showcase/winvista_licensing.asp
Windows transfer rights
There's a funny myth going around that says you have a right to transfer a single copy of Windows XP (or any previous Windows version) to as many computers as you like, as often as you like, and for any reason you like. This myth exists because the Windows XP EULA is vaguely worded. It states, "You may move [Windows XP] to a different Workstation Computer. After the transfer, you must completely remove [Windows XP] from the former Workstation Computer." Pundits argue, incorrectly, that this EULA implicitly allows any user to continually move a single copy of Windows XP from machine to machine as often as they'd like. One online pundit decided this meant that "there are no restrictions on the number of times you can transfer the software from one computer to another in your household or office." That person is, however, incorrect. As it turns out, the Windows license is pretty simple: Windows is tied to a single device (typically a PC), and not to a person.
