XP Pro SP2/Vista Beta2 dual-boot
"not interfere in any way"
that means youd have to remove/disconnect the XP drive as installing Vista in a dual boot will mess with the XP bootloader, so youd have to swap hard drives when you want to use one or the other.
Pretty straightforward. Boot from dvd, select the drive you want to install on, wait an hour and reboot. You'll have a boot menu with "earlier verion windows" and "microsoft windows". Select the one you want to use.
That the way it worked for me no problem with the vista install running like a champ and remember its beta also loaded the beta of Office to see how it works fine Vista will be the next operating system to save for in the future has a lot of nice features once you get to know your way around.
