XP Game Slowdown
Fliping
I'm currently having a problem with playing a couple games. I did a fresh install of XP (SP2) a few weeks ago and have only really been playing SC since then. I thought the problem was with Just that game because of the problems people had with the Beta (memory leaks etc.). What happens is, usually after 5-10 minutes of playing or so, the game slows to a crawl, going from like 30fps to <15. I can fix it temporarily by pausing it for 10 seconds or alt+tabing to windows and going back in. The problem comes back after 30 seconds or less of playing again. I figured it was a problem with my video card not having enough RAM, or my page file. I searched the internet some more and found that some people were applying a patch for the P4D 2.66 CPUs and it was fixing a lot of problems. I applied this patch and followed the steps, but it fixed nothing. I also tried playing the game with /nosound and changing my dxdiag sound to "basic". It seemed not to slow down as frequent when I had sound disabled.
Just the other day my girlfriend wanted to try out LOTR:BFME2 and after she was playing only for a couple minutes, the same thing happened. I was totally surprised as I thought the problem was local to just SC. This has never happened before and I have had the same system setup for quite some time now. I'm a little stumped with this. I have yet to try any other games, but I'm guessing the same thing will happen.
Someone will probabbly suggest re-installing windows, which I will most probabbly do soon anyway. Is there anything anyone can think of that would be the problem? Like I said, this has never happened to me before and my rig has been the same for months. The only thing I changed back in Nov-Dec was my motherboard/cpu. Up until recently, everything has been fine. My system has been formatted many times since then for Vista and back to XP.
My system specs are:
P4 Dual Core 2.66
Asus P5PE-VM
1.25GB DDR Ram (1x1024, 1x256) [Have also tried taking out the 256 but no change in performance]
ATI X850 Pro AGP (256mb)
250GB SATA2 HD
Audigy 2 Value
Enermax 350W PSU
Any advice would be Greatly appreciated. Thanks everyone.
- Have you updated your drivers?
- What programs are you running in the backgroud?
- Google HDTune. Download, install, and run it.Click the Error Scan Tab and scan your hard drive
- Run Anti-Virus. Anti-Spyware, and Anti-Adware scans
- Click Start, Run, enter in "eventvwr" without the quotes. See what errors show up in the "Application" section as well as the "System" section. \
Hopefully one of these suggestions will help.
Thanks for your reply. Every time I format my system I get the latest drivers for all of my hardware. Nothing besides ATI Tool and my Logitech SetPoint software for my G7. I usually close all apps when I game. HDTune doesn't find any errors on my disk as well. Anti-spyware scans came up with only the normal tracking cookies etc and NOD32 didn't detect anything. Nothing in event viewer shows up relating to system problems for the time I'm playing games either. I'm still pretty much stumped. I appreciate your advice. If anyone else has anything to add, I'm listening =)
Not that many people care or anything, but I found the problem. I had recently installed keyboard drivers for my Logitech Internet Keyboard. The problem started around then. I was re-installing a friends copy of XP last night and asked what she wanted installed (driver wise).. she told me No to the keyboard drivers and said it slows down CS for her. Luckily enough, she had the same keyboard as me, so when I got home I removed them and eureka! (if that's spelled right). :D :D
The moral of the story is... never overlook anything, LoL.
