TheGreySpectre
- May 1, 2005
Consoles are primarily living room devices, and most people don't want to be dealing with a keyboard/mouse in that environment. Controllers aren't dumbed down, they just happen to be the best input method for how and where people play console games. Plus have you ever tried to play a local multiplayer game with keyboards and mice on? Good luck with that.
A keyboard and mouse is a controller for 1 person. If you wanted to play local multiplayer with kb/m you would have 4 keyboards and 4 mice. Just like if you want to play local multiplayer with standard console controllers you use multiple controllers, you don't cram four people onto a single controller.
I have used a keyboard and mouse from my couch many times, it works just fine. If you have problems finding a surface to mouse on then you can just use a trackball, people should be given options on how they want to play. What makes the fact that you like controllers a more valid opinion then the fact that like kb/m?
In regards to the people saying it only supports 11 games:
It currently has 11 smart configs, not 11 overall games it is compatible with. For the 11 games that it has smat config with it will be 1:1, for the other games it should be the equivalent of an XIM2 or perhaps better. Since people were quite satisfied with the XIM2 they should likely be even more satisfied with the XIM3. I know the XIM2 has a active community with people posting their configs so you should be able to find a config for any game you want to play.
