Negative Decibel
- Dec 13, 2005
Ok, Here's the deal. A few months ago, I decided to replace my old Zalman CNPS9500 Heatsink/fan with the Xigmatek HDT-S1283 (and optional bolt on kit). Unfortunatly, the northbridge heatsink on my evga 680i motherboard, was getting in the way. I thought it would be ok because just the bottom few fins were bending up ever so slightly, but apparently it was just enough for the whole damn thing not to seat properly, and refused to boot...
So, a few months have gone by, and I've been staring at the Xigmatek box too long. Why not cut a few fins off, right? And I needed some better cable management to help keep airflow good...
Time for some pics...
Here is my untidy case with the Zalman hsf, and half ass cable management:
The Xigmatek HDT-S1283 in all it's glory (and bent up fins from taking the fan off the last time in frustration:
Time to remove some fins. No Dremel? No problem... I'm going old school with a hack saw!
Much better...
and, viola! It fits!!
installed the fan, and unbent the fins with a butter knife before reinstalling the motherboard back in the case. Now to work on the cable management. I purchased 6" 8-pin and 24-pin psu extension cables so I could run them behind the motherboard.
back:
front:
Much better...
back:
front:
