XG External 600w PSU
Viper87227 said:
What exactly is the point of such a thing?
The PSU can be any size so it can work with any case. Furthermore, the performance of the power supply is not affected by the ambient heat within the case.
That said, MGE should've taken this as an opportunity to make the power supply more powerful.
I can't speak of the quality of that brand, and they don't provide the combined wattage of the duel 12V rails OR the 3V + 5V rails. It might power the system, but I wouldn't count on it.
So you're incapable of dong any research on a product before you consider buying it?
Not that you were considering buying it... but I'm just trying to figure out what your point is.
