- Jan 20, 2005
First system specs
6600 2.4 overclock @ 3.8 1.42v watercool
8 gigs DD22 pc-8600 gskill brand
1 x 4870x2 Sapphire with an Accelero Xtreme cooler
1 x 4870 XFX so crossfireX setup i guess
P5Q-E mobo
Corsair 850XT
etc.
Here's the story my 4870 1 gig XFX started going bad about 5 days ago. First it would completely disappear from the device manager & CCC for no reason I also notice a light turning on the D601 led. Searching the forum I found out D601 means "critical temperature fault" meaning its overheating? The video card was not overclock or volt modded or anything I ran it at stock speeds since i saw no reason to overclock it (I can run most games at high settings without issues with my current setup).
So after trying the card by itself with 2 different PSU's (my Corsair 850XT and a OCZ 700 PSU) multiple setups (running it by itself , switching pci-x lanes etc) I decided its time to send it to XFX.
My question to some of you guys who had dealt with XFX RMA dept, how long did the RMA process take& if they don't have a 4870 1 gig available what should I expect as replacement ?
I did search the forums & found a few bad experiences but seem like it was the user fault at hand. So any ideas what the D601 LED means? or experiences with XFX warranty? I know they're located locally I'm close to Los Angeles so the round trip to XFX shouldn't be too long.
Thanks
P5Q-E mobo
Corsair 850XT
etc.
Thanks
